Oil Smells like gas - JeepForum.com
post #1 of 10 Old 06-17-2008, 05:35 PM Thread Starter
jbrink
Oil Smells like gas
I just switched to synthetic oil a few weeks ago and now it seems like my oil smells like gas. Another thing it seems like my oil pressure is a little higher when I first start up the engine. I put in 10w30 because it's summer. I don't know if that may have something to do with it. Any ideas or suggestions?
jbrink is offline
post #2 of 10 Old 06-17-2008, 06:24 PM
pigoo
Don't know your vehicles mileage...but worn but engine wear can allow oil & fuel to mix to a degree.
I would say that your oil smelling like gas was probably present before you used the synthetic oil...you just so happened to notice now with your most recent oil change.
- Nick
pigoo is offline
post #3 of 10 Old 06-17-2008, 06:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it was bad valve seals on my 318, could be rings as well though.
ratmonkey is offline
post #4 of 10 Old 06-17-2008, 07:13 PM
ZJcrawler45
Could be numerous things, the 2006 raptor 700's are notorious for this, and no one can find the problem; and also nothing bad has happened.
ZJcrawler45 is offline
post #5 of 10 Old 06-17-2008, 08:54 PM
Chrisca
Chrisca's Avatar
Instead of 10W-40?
If you change weights, you would change to heavier (10W-40) in the summer.
The 1st number is the viscosity at colder/startup temps and the 2nd number is the viscosity at operating temp.
Hotter in the summer means thinner oil.
2004 Grand Cherokee Laredo
Chrisca is offline
post #6 of 10 Old 06-18-2008, 08:32 AM
Coletrickle
Could it be a leaking throttle body; leaking fuel that's washing past the valves and rings and mixing into the oil?
Is it showing signs of being overful of oil? That would tell you how serious it is. If it's not overful by much, it can't be much gas.
93 Grand Wagoneer
5.5" Hybrid Lift/BDS CA's
231/skids/33" KM2's
Homegrown Bumper
Aussie
Coletrickle is offline
post #7 of 10 Old 06-18-2008, 11:25 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
There is no fuel into the TB, its all injected in the head (multi-port fuel injection).
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #8 of 10 Old 06-18-2008, 12:09 PM
Coletrickle
oops, sorry. What I should have said is what about a leaky injector?
93 Grand Wagoneer
231/skids/33" KM2's
Homegrown Bumper
Aussie
post #9 of 10 Old 06-18-2008, 12:12 PM
Double E
Double E's Avatar
Chris makes a good point. The use of a more thin (thinner?) oil in summer is exactly backwards to what you'd want to do.
Given that it is synthetic however, the change in viscoscity in varied temperatures is less an issue than with conventional.
A compression check will tell you about the issue being with cylinders & valves sealing well enough.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #10 of 10 Old 06-18-2008, 04:45 PM
rubbersidedown
does it seem to be missfiring? Could be a bad spark plug.
rubbersidedown is offline
Aircondition smells like rotten egg :( Nonni WK Grand Cherokee & XK Commander Forum 5 09-23-2009 12:46 PM
Something smells like it's burning? gatorayde ZJ Grand Cherokee Forum 8 12-26-2008 03:42 PM
WK CRD smells AJ+SJ WK Grand Cherokee & XK Commander Forum 23 11-04-2008 12:14 PM
Heat / Def. Smells robbaseny ZJ Grand Cherokee Forum 1 05-03-2008 09:37 PM
Air smells really bad! 95_Jchke ZJ Grand Cherokee Forum 6 09-10-2006 05:34 PM
