Oil and seafoam - Page 2 - JeepForum.com
post #16 of 26 Old 05-23-2011, 03:25 PM Thread Starter
Howieb92
OK I not that great under the Hood yet where is the brale booster line?
Howieb92 is offline
post #17 of 26 Old 05-23-2011, 04:29 PM
Freestyle713
1994 ZJ
there is a big black cylindrical thing (get your mind out of the gutter ) on the drivers side mounted on the firewall. right behind where the brake fluid goes, i think its like a yellow tank. there will be a hose going into it with or without a clamp on it, i cant remember. just pull that off and when the engine is running the hose sucks air like a vaccum. thats where the seafoam goes. and just a pointer, instead of pouring the seafoam into the hose, just put the seafoam in a cup and put the hose into it and let it suck up the water on its own. remember, a little at a time. if you are only getting one can of seafoam, use half in the vaccum line and half in the gas tank, but put it in the gas tank when the tank is nearly empty, then fill your tank with gas, that way it all gets mixed in.
Freestyle713 is offline
post #18 of 26 Old 05-23-2011, 05:49 PM Thread Starter
Howieb92
Here at orielys it buy two get one free. So how much should go in the TB and vac lines?
Howieb92 is offline
post #19 of 26 Old 05-23-2011, 05:53 PM
Freestyle713
1994 ZJ
if you get three, then put a whole one in the gas tank, half in the vaccum lines, half in tb, and save the other can to put in the gas tank another time
post #20 of 26 Old 05-23-2011, 06:48 PM
ScottyGunn
I love "spirited drives"!
Newby with first Jeep!
ScottyGunn is offline
post #21 of 26 Old 05-23-2011, 07:45 PM
MaintMech
Old and in the way
MaintMech's Avatar
There's a pretty good thread on here.
Seafoam=WOW.
Search it out, it'll explain everything!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #22 of 26 Old 05-23-2011, 07:46 PM Thread Starter
Howieb92
OK thanks much guys for all help
Howieb92 is offline
post #23 of 26 Old 05-24-2011, 11:35 AM
rritch
So I am planning to sea foam my top end and add it to the gas tank to clean the injector. I have a 98ZJ 5.2L. What I am not clear about is since it is Throttle body if I still need to do it through the brake booster line of I I can just pour it into the throttle body, or if I should do both. Can anyone shed some light on this for me?
98 ZJ 5.2L Limited, 2.25" Budget Boost, 31x10.5x15 Definity Dakota MTs, Westin Safari Bar, Hella 500 Driving Lights.
rritch is offline
post #24 of 26 Old 05-24-2011, 12:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
when you sea foam. check your intake. if you have a v8, look down the throttle body and see if there is a divider plate in the plenum. if there is a plate you MUST add the sea foam down the throttle body. if there is no plate a large vacuum line like the brake booster line will work. either way you should remove and clean the throttle body and iac by hand once a year.
i believe 96 or 97 was the tranisition year away from the divider. no 98 i've seen has the divider, all 96's i've personally looked in have the divider, some 97's have the divider.
ratmonkey is offline
post #25 of 26 Old 05-25-2011, 06:40 AM
MuddSlutt
when my intake plenum was leaking, id top off with a quart of ATF when it came close to an oil change, no problems.
01 WJ 4.0 ((New Toy))
98 ZJ 5.9 Limited ((SOLD))
MuddSlutt is offline
post #26 of 26 Old 05-25-2011, 09:27 AM Thread Starter
Howieb92
I seafoamed last night now instead of mid 13 MPG now its mid to high 15. MPG
Howieb92 is offline
