Oil pump replacement in 4.0 - any hints? - JeepForum.com
post #1 of 17 Old 12-16-2006, 08:31 PM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
Hi guys!
Today, on my way to the movies I've notices that my oil pressure dropped down to 20psi when idling. And the engine started to make some sound, which (forgive me my English) I would call chirping. Like I have small bird in the engine, somewhere in the middle (between 3rd and 4th cylinder) definitely on the right side.
As the pressure wasn't to high before (around 38psi when hot comparing to my XJ's 42 at hot) I suspect that my oil pump is dying.
Now:
a) Is my diagnose right? or is there something else going bad in those engines?
b) Is there anything I should be aware of before I'll take the old one out? Anything to check while I have oil pan down?
92 XJ Laredo Mods: bored TB, 3" lift, 1-ton steering
93 ZJ Limited Mods: bored TB, K&N insert, e-fan; prothane bushings, NP242J, 3" lift, 1-ton steering; Atlas winch
Kornik is offline
post #2 of 17 Old 12-16-2006, 08:52 PM
JFM626
JFM626's Avatar
Don't rely on the electrical gauge to be accurate. Use a mechanical one to be sure before tearing into your engine.
JFM626 is offline
post #3 of 17 Old 12-16-2006, 09:00 PM
-Joe-
-Joe-'s Avatar
20 psi isnt low..
I believe something like down to 13 is supposed to be normal..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 17 Old 12-16-2006, 09:06 PM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
Of course I will, but what about the sound? To me it's like a shaft turning without lubrication in it's bearing.
Kornik is offline
post #5 of 17 Old 12-16-2006, 09:10 PM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
Originally Posted by -Joe-
20 psi isnt low..
For me anything above and below 40 psi is not normal - that's why the pressure relief valve is there. I accept up to 50 psi when it's 15 degrees outside. But after it's warmed up it should stay level no matter what. And I know it can, as I have XJ with same engine and similar millage and there the pressure is staying on 42 all the time no matter if I have 650 or 3000 RPMs.
Kornik is offline
post #6 of 17 Old 12-16-2006, 09:18 PM
-Joe-
-Joe-'s Avatar
Im just stating what the manual says..
Mine has always changed according to temp and speed. ITs never been steady.
- Joe -
-Joe- is offline
post #7 of 17 Old 12-16-2006, 09:24 PM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
So maybe I'm overreacting, but
a) as I said before it's staying level in my XJ after warm up on 42psi,
b) next Monday I'm going to make some 2000 miles trip to Colorado, and I would love to make it safely back and make it in my ZJ. If I won't be sure about it's being reliable enough I'll be forced to take XJ and it's something my wife won't like.
Kornik is offline
post #8 of 17 Old 12-16-2006, 09:37 PM
-Joe-
-Joe-'s Avatar
Not about the noise.. I would be concerned.. But my 4.0 is loud anyways.
I changed my oil pump due to a noise i thought was it.. My pressure still remained the same with the new pump, its just never been steady. Could be my worn engine though.
- Joe -
-Joe- is offline
post #9 of 17 Old 12-16-2006, 10:24 PM
anticrombie
anticrombie's Avatar
Oil pressure shouldn't stay the same. It fluctuates with the RPM's of the engine.
Charlie
anticrombie is offline
post #10 of 17 Old 12-17-2006, 04:47 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Basically the oil pressure gage tells you that the oil pump is working. That’s about it! The gage is not necessary to have. That is why most vehicles don’t have them. If however you notice that the gage is reading different than normal, then I would replace the filter, no matter how old it is, and then I would have a good look at the sending unit (transducer). They are known to act up. Unplug the electrical connector and inspect it for oil leaking into the connector. I would replace the transducer first before replacing the oil pump.
From the FSM: For the model years (1993 to 1996) 4.0L engine: the oil pressure at 600 rpm should be around 13 psi. At 1600 rpm and higher the pressure should be between (37 – 75psi)
So Anticrombie is very correct. Oil pressure is directly proportional to rpms. Temperature and viscosity will have a minor effect on it as well.
The only time I heard a bird chirping in the engine bay area, was when my friends Jeep had a bad distributor bearing!
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #11 of 17 Old 12-17-2006, 07:09 AM
Katesdad
Katesdad's Avatar
Distributor bearing would be easy to check, just remove cap and rotor and see if there is any play in the shaft. One thing that helps alot is using a long screwdriver as a stethescope <-- not spelled right? You can zero in on the sounds inside the engine. My two chirping noises have come from the A/C compressor clutch and the idler pulley. Oil shavings will show up pretty quick in the oil if its a bad bearing within the engine. Just keep a close eye and ear on it and change the oil soon.
My oil pressure is all over the place too.
Katesdad is offline
post #12 of 17 Old 12-17-2006, 07:21 AM
SnaFu2
Hi guys!
Now:
OIL PUMP PRESSURE
The MINIMUM oil pump pressure is 89.6 kPa (13
psi) at 600 rpm. The MAXIMUM oil pump pressure
is 517 kPa (75 psi) at 1600 rpm or more.
The above was taken from the '97 FSM.
Didn't see anything about a "chirp" though.
SnaFu2 is offline
post #13 of 17 Old 12-17-2006, 08:11 AM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
OK maybe I'm a little bit overreacting, but I don't believe in coincidences and that sound showed up exactly at the moment the pressure gauge started to behave as I said. Before that readings were steady around 38-40 psi almost like in my XJ. That's why I'm suspecting oil pump. Anyway, I'll closely examine everything today before I'll tear down oil pan and pump. I'll drain oil and will look for metal in it. I think I will even drop down the serpentine belt and examine idle puller - as you suggested.
Kornik is offline
post #14 of 17 Old 12-17-2006, 09:01 AM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
That will be easy to check, I will swap them between my XJ and ZJ and see if the sound goes ofter :-)
Kornik is offline
post #15 of 17 Old 12-17-2006, 03:03 PM Thread Starter
Kornik
Not so newbie :-)
Kornik's Avatar
That's why I love this forum - I swapped distributors with my XJ (actually I just put the XJ's one in the ZJ) and sound stopped! Now I have to find new distributor for my XJ :-)
As for now I will leave the oil pump intact closely observing how it behave in near future.
Thanks again!
Kornik is offline
Water Pump replacement RyanSBenson ZJ Grand Cherokee Forum 3 02-23-2009 05:33 PM
Oil pump replacement gomes512 ZJ Grand Cherokee Forum 6 04-17-2007 01:40 PM
Fuel Pump Replacement JetBote ZJ Grand Cherokee Forum 2 09-27-2006 06:18 AM
Fuel Pump Replacement Test ZJ Grand Cherokee Forum 11 06-14-2006 07:26 PM
Water Pump replacement buysell123 ZJ Grand Cherokee Forum 4 08-13-2004 12:39 PM
