Oil pump or pressure sensor? - JeepForum.com
post #1 of 4 Old 10-21-2007, 08:05 PM Thread Starter
Yardman Harry
O
Yardman Harry's Avatar
So Im driving along on the highway today, and I pull off to the shoulder to re-adjust the tarp on my trailer. When I come to a complete stop, the check gages alarm sounds, but before I could figure out what the deuce is happening, the alarm goes away.
Later, I come to a complete stop at the light, alarm sounds and this time i can see the oil pressure dropped to zero. At which point the light turns green and i get going again. The pressure returns to normal and I continue to drive @ 70mpph. Stop at another light, and only at a complete stop, the alarm sounds and the gage drops to zero.
This pattern continues for my ride home tonight. Only when I come to a complete stop, if i am rolling, nothing, but when I stop, gage drops and alarm sounds. As soon as I start moving again the system returns to normal.
Any Ideas?
Thanks!
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #2 of 4 Old 10-22-2007, 08:22 PM Thread Starter
Yardman Harry
O
nothing for the Harry dude?
Thanks guys!
Hunter Green
White
~Junked~
post #3 of 4 Old 10-22-2007, 10:03 PM
ZJMAN
Pull the oil pressure sensor. They are famous for erratic readings. Check the pressure at idle, 1000 RPM, 2500 RPM and 3000 RPM cold and hot. General rule is a minimum 10 Lbs. for every 1000 RPM. If presure is ok, replace the sensor. If it's low, it's pump time. I bet that it's the sensor.
ZJMAN is offline
post #4 of 4 Old 10-22-2007, 10:24 PM
Vestjam
Probably the sensor...
Plus, it's cheaper and quicker to replace than the pump. IF it doesn't change anything, you have a new sensor for the pump you may be buying now.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
If I was an Oil Pressure Sensor for a 99 4.7l WJ j_dennis13 ZJ Grand Cherokee Forum 1 11-23-2009 02:47 PM
Oil Pressure/ Bad Sensor? hrjaw ZJ Grand Cherokee Forum 2 12-06-2005 10:32 AM
Oil Pressure Sensor 4weeln ZJ Grand Cherokee Forum 1 03-29-2005 07:35 AM
Oil Pressure Sensor KWP1911 ZJ Grand Cherokee Forum 3 12-12-2004 04:29 PM
