Oil pump . - Page 2 - JeepForum.com
post #16 of 29 Old 07-13-2013, 12:44 AM
Uniblurb
Uniblurb's Avatar
Below is what your oil pressure sending unit looks like but this price may be a little high. It's best to take your old one in to match it up because they come in different lengths and can sell you the wrong one.
http://shop.advanceautoparts.com/web...bwd_19970187-p
Can't imagine your oil pressure actually dropping to zero or your engine would be making a bunch of racket and may come apart. You could probably remove your valve cover cap while running and see if it's spitting oil/flowing.
I'd be replacing your sending unit first since dropping the pan to replace the oil pump is a pain. Also agree on putting a new rear seal in it and don't buy the cheapest oil pump if you end up doing this. Use only a Mopar or Felpro pan gasket and rear seal. Hopefully you won't have to go this route and good luck!
BTW, with a 4" lift you may not have as much problem as I did in getting the pan out on my 96 4.0. Had to remove the top shock nuts, the sway bar link nuts on the bottom and finally the track bar bolt to get the axle to drop down far enough to get the pan out.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #17 of 29 Old 07-13-2013, 01:47 AM Thread Starter
Jramos43
The gauge marks 0 and my engine runs smooth and perfect. I actually drove it for bit and it didnt have any clunky noises nor was the engine.failing
96 ZJ
Jramos43 is offline
post #18 of 29 Old 07-13-2013, 01:56 AM
Uniblurb
Uniblurb's Avatar
Well I'd just replace the sending unit and you'll probably fix the problem. I normally put some teflon tape on the threads so it doesn't leak and you don't need to torque it a whole lot or it will break.
post #19 of 29 Old 07-13-2013, 09:33 PM
Kevinyj95
No way its the oil pump then. its either the gauge or the sending unit. But as said Above my moneys on the sending unit. Its a tight fit and requires a special deep well socket. But its a 5 min job. I screwed mine in with the socket hand tight. I believe it comes with the tape on it now. depending which one you buy. Don't bend it when removing or installing. Put the socket straight on and remove/Install or you will break it off in the threads. Its delicate. When you have low oil pressure. Its starves the engine for oil. It starts with a chattering in the top end. Then knocking then the wonderful squeal of the camshaft. If it doesn't go before then.
Kevinyj95 is offline
post #20 of 29 Old 07-15-2013, 12:08 PM
JohnnyZJ
i'm betting your valve seals are gone and your motors ****ed.
but then again i'm a pessimist....... who has had the EXACT same symptoms you are describing. check your oil level lately? does it burn blue? might wanna check those as well.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #21 of 29 Old 07-15-2013, 12:27 PM
Kevinyj95
Wouldn't there be a lot of smoke?
post #22 of 29 Old 07-15-2013, 01:21 PM Thread Starter
Jramos43
No my engine isn't ****ed it still turns on.and drives , so i don't think so
96 ZJ
Jramos43 is offline
post #23 of 29 Old 07-15-2013, 02:39 PM
dnuccio
People keep telling me that the sending unit and the oil pump are the same thing, whats the difference ?
those people are what we refer to as idiots. dont listen to them
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #24 of 29 Old 07-15-2013, 03:39 PM
Kevinyj95
I wish I could change my oil pump w/o dropping the pan. Just unscrew it from behind the intake manifold. Whoever is telling you this is clearly retarded or attempting to rip you off. Here it is http://www.autozone.com/autozone/par...966605_0_8450_ Heres a pic of it Lol I just realized some one already did this.
post #25 of 29 Old 07-15-2013, 03:52 PM
Kevinyj95
If it was your oil pump your engine would already be toast if you've been running it and driving it like you say. I don't think its your valve seals or there would be a lot of smoke. Burning oil. Im pretty sure you need to go to that parts store and pick up the part and socket and replace it. Easier than getting gas. Well unless its full service.
post #26 of 29 Old 07-15-2013, 03:55 PM
Kevinyj95
You can show these pics to those people ask if they can see the difference. oil pump and sending unit/switch
post #27 of 29 Old 07-15-2013, 04:13 PM Thread Starter
Jramos43
I already swapped it out, turns out that was the problem haha thanks
96 ZJ
Jramos43 is offline
post #28 of 29 Old 07-15-2013, 05:55 PM
Kevinyj95
No problem glad we could save you the trouble of having to replace the oil pump.
post #29 of 29 Old 07-15-2013, 10:22 PM
JohnnyZJ
Mine ran fine too
Glad you found yiur issue and it wasnt to bad
JohnnyZJ is offline
