oil pressure sending unit -- where is it? - JeepForum.com
post #1 of 17 Old 09-20-2008, 10:29 AM Thread Starter
alivenkickin28
I cannot get the search feature to work today --but on the 5.2 litre -- can someone tell me where the hell the oil pressure sending unit is located?? I cannot find it anywhere??? 1995 Grand CHerokee 5.2ltr -- thanks!
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #2 of 17 Old 09-20-2008, 10:45 AM Thread Starter
alivenkickin28
cmon nobody knows???? whose got apic?
post #3 of 17 Old 09-20-2008, 12:13 PM
BlingBlingZJ
well i'm also trying to find it as my gauge is going all crazy.. some say it's behind the distributor it's a tight area and so far I have not been able to find it. Let me know if you find a way to take it off
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #4 of 17 Old 09-20-2008, 02:29 PM Thread Starter
alivenkickin28
okay i felt to the left of the distributor and down....then i felt the electrical connector....soooo thats where it is and its going to be a BCH to get to....so im takin mine to the mechanic - i have a tire that needs plugged anyway....i dont even know how you'd get somethin down t here to change it and i dont want to break it for sure....
post #5 of 17 Old 09-20-2008, 03:00 PM
Virmagicus
Virmagicus's Avatar
Was going to answer but it sounds like you found it. Yes , it has the two wires coming out of the top of it to the left of the distributor.
Jeff
Virmagicus is offline
post #6 of 17 Old 09-20-2008, 05:31 PM Thread Starter
alivenkickin28
well i couldnt stand it - -had to get it fixed so i broke down and banged up my hand a little cussed drank and cussed some more but got it replaced...took bout 30 min once u get the right socket to fit....u have to feel around cuz you can't see but its not bad...
post #7 of 17 Old 09-20-2008, 08:52 PM
Darthteddy
1955 M-38
Yea its a pain. Right in the back behind the intake manifold. . .
Dont be stupid like me and accidentally put the new sender in one of the open threaded holes in the intake manifold. . .
Was a guizer of Oil. Then i did it again with another hole right near it. haha
Brickwall
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #8 of 17 Old 09-21-2008, 01:19 PM Thread Starter
alivenkickin28
nope so far so good -- went out last nite in it and everyting was fine -- back to readin oil pressure
post #9 of 17 Old 09-21-2008, 01:31 PM
BlingBlingZJ
damm I've been looking forever and didn't find it I even looked behind a 5.2 that was on the junk yard and still nothing I must be blind well you give me hope to look for it again today maybe I will find it. What socket did you use to get it out? did you use extensions?
post #10 of 17 Old 09-21-2008, 01:35 PM Thread Starter
alivenkickin28
on the 5.2 you cannot see it you have to feel for it...take your hand hopefully urs are not too big and you see the distributor, push your hand down to the left of the distributor and down there you will feel it...i had to get a long socket so that it would go down over the plug part of the sensor i believe its a 1 or 1 and 1/16 socket that i used -- its easy to measure by the new one -- should be same size...the plug will prob break off when you go to replace it and just make sure you're careful putting the new on on...i had to put the socket down on the sensor, then a small extension then put the wrench - -you have such limited space....takes bout 30 min in between cussing and drinkin more beer...lol
post #11 of 17 Old 09-21-2008, 03:02 PM
Darthteddy
1955 M-38
Yea its the thing stickin up beside the distributer.
Go to the auto parts store and buy yourself a 1-1/16" Oil Pressure Sending Unit Socket. They are like 5 bucks and you will get your use from it if you use it once.
post #12 of 17 Old 09-21-2008, 03:23 PM
BlingBlingZJ
ok sounds good. Good thing I have such skinny hands maybe it makes it easier
i will go out and look. Thanks
post #13 of 17 Old 09-21-2008, 03:26 PM
BlingBlingZJ
would a bad sending unit make the needle go crazy up and down. I have a feeling that it is also leaking as I have a oil leak that I have not been able to find .
post #14 of 17 Old 09-21-2008, 03:31 PM Thread Starter
alivenkickin28
yes it can make it act like that - mine just read 80 all the time and wouldnt move....now its fine...
post #15 of 17 Old 10-20-2012, 07:44 PM
95cherokee318
ok guys ready for this one??? i have had a small oil leak for about a month.. figured probably valve cover gasket, as i just had them off and painted them not long ago... NOPE!!
Today I changed the oil.. then what was a very small leak became a waterfall of oil... I searched and saw that it was pouring out of my sending unit...!! I'm not sure how bad off we are yet but i had to use over 3 gallons of oil to get home form about 10 miles away.. got home in a HUGE cloud of smoke and an empty oil dipstick.. please everyone, cross your fingers and knock on some wood for me and my ZJ..
95cherokee318 is offline
oil pressure sending unit zippome ZJ Grand Cherokee Forum 6 11-20-2009 04:36 PM
Oil Pressure Sending Unit? PoliceDrummer ZJ Grand Cherokee Forum 3 04-19-2009 09:30 AM
Oil Pressure sending unit jeeper_creepers ZJ Grand Cherokee Forum 5 08-06-2007 10:22 AM
'01 Oil Pressure Sending Unit mbspark1 ZJ Grand Cherokee Forum 6 11-15-2006 09:42 AM
oil pressure sending unit JeePing21 ZJ Grand Cherokee Forum 3 08-25-2006 02:37 PM
