Oil pressure problem? - JeepForum.com
post #1 of 9 Old 07-19-2009, 05:33 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
My jeep has been seeming to have a low oil pressure for a while now. Is this bad? How do I fix this? It seems to fluctuate as I am driving sometimes, and when I go up hills the jeep will start to smell like a burning kinda smell or a warm smell. I'm not low on oil I just changed it today brand new filter on. What could be causing this problem?
Mudzilla6661 is offline
post #2 of 9 Old 07-19-2009, 05:50 PM
SouthSeaPirate
Oil pressure sending unit. Check the contacts and look for any leaks. Located right around the distro area.
SouthSeaPirate is offline
post #3 of 9 Old 07-19-2009, 05:54 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
ok ill check that is it hard to replace? how much does it cost?
post #4 of 9 Old 07-19-2009, 06:11 PM
SouthSeaPirate
Might be a bit of a ***** to get to without a OPSU socket. I have one and it makes it a ton easier. Its under the lip of the distro if IIRC which makes it hard to get to with pipe pliers or wrench.
Does the gauge flicker back and forth? If so its deff a problem. May not me the problem but it is a problem...
post #5 of 9 Old 07-20-2009, 05:00 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
yeah at first in the morning the gauge goes back and forth between the level posted in the pic above then to about mid way at 40 then back down
post #6 of 9 Old 07-20-2009, 09:52 PM
SouthSeaPirate
Sound's a lot like its leaking. Have you checked it out already?
post #7 of 9 Old 07-21-2009, 04:53 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
yeah, I think it may have a small leak would that cause the pressure fluctuation?
post #8 of 9 Old 07-21-2009, 01:47 PM
SouthSeaPirate
For sure! Check and see if its coming from the threads, if so you may be able to get by with cleaning the threads a placing it back in. Good luck
post #9 of 9 Old 07-22-2009, 05:09 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
no I think it is coming from the oil pan itself I have a small dent in it from when I bought it and now I think it is starting to leak. Is there something to put on it to stop the leak or do I have to buy a whole new oil pan? which would be better? Would fixing this restore some of the power I feel I have lost?
Oil pressure problem goose2125 ZJ Grand Cherokee Forum 7 10-22-2008 12:20 PM
Oil Pressure PROBLEM dels383ta ZJ Grand Cherokee Forum 4 04-09-2008 09:05 PM
Please Help. Oil Pressure Problem. bigman ZJ Grand Cherokee Forum 6 03-12-2007 08:41 AM
Problem With Oil Pressure skisprinkle686 ZJ Grand Cherokee Forum 16 02-11-2007 02:34 PM
Oil Pressure Problem Chuck831 ZJ Grand Cherokee Forum 11 11-08-2002 12:55 AM
