oil pan removal - JeepForum.com
post #1 of 8 Old 03-14-2007, 01:42 AM Thread Starter
abranz
oil pan removal
I'm planning on a timing chain, oil pan and rear main seal job on my 93 5.2 and wondering if anyone has tips on this project? In particular removing the oil pan. Many thanks, Tony
1993 GC 5.2
abranz is offline
post #2 of 8 Old 03-14-2007, 03:37 AM
topjoe
Tip #1 drain oil first makes it alot easier but ya I dont no what else you want to hear other then removing the bolts on the pan to drop it haha
1996 Jeep ZJ - ARB BULL BAR, K&N Intake, MSD Ignition Wires,Hippo Lined Interior, IPF 6" lights on the Bullbar, JKS Swaybar Quick Disconnects , 3 1/2 Rubicon Express Super Flex, 2" coil spacers in the front,33" Super Swamper TSL's
topjoe is offline
post #3 of 8 Old 03-14-2007, 09:00 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Pull the motor. Easier really.
HighLonesome is offline
post #4 of 8 Old 03-14-2007, 09:03 AM
Ds4x4
Ds4x4's Avatar
theres other posts on dropping the pan.. some have said the exhaust gets in the way... best thing is to crawl under and plan out the drop a little before the time comes to actually do it..
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #5 of 8 Old 03-14-2007, 09:32 AM
Vestjam
There's no easy answer. The FSM talks about doing it when still in the vehicle, but that's at a shop with a lift and other specialty lifting/support tools to make the job easier.
For guys like me, it means putting the vehicle up on 4 jack stands, raising the motor up from the harmonic balancer to get enough clearance to slide the pan out and then getting the work done.
If your doing the timing chain too, I think I would consider pulling the motor just because you are already moving stuff out of your way to get to the timing chain.
If there's really nothing wrong with the pan and the rear seal isn't loosing lots of oil, I'd just do the timing chain... but I don't know the situation.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #6 of 8 Old 03-14-2007, 09:39 AM Thread Starter
abranz
Thanks for the replies. I should have been more specific in my questions. Just wanted to know if the pan could be removed without lifting or removing the engine. Tony
1993 GC 5.2
abranz is offline
post #7 of 8 Old 03-14-2007, 09:43 AM
HighLonesome
You must do the oil pan gasket when replacing the timing set because the timing cover must come off. I just hit this wall after blowing a timing cover gasket. And I have a seeping rear main seal, which is a bear to do when on your back. The harmonic balancer needs to come off too, so you need to pull the radiator to keep from mangling it. After careful thought, the motor comes out this weekend.
post #8 of 8 Old 03-14-2007, 09:44 AM
HighLonesome
The answer is yes.
Tie Rod End Removal pigoo ZJ Grand Cherokee Forum 3 06-14-2008 09:05 PM
95 ZJ fuel line removal & Oil filter removal Ahardy4 ZJ Grand Cherokee Forum 6 12-02-2007 03:33 PM
4.0 oil pan removal rxl ZJ Grand Cherokee Forum 4 09-22-2007 09:12 AM
'98 GDM/VIC removal Reswob ZJ Grand Cherokee Forum 11 12-16-2005 05:37 PM
oil pan removal 900Steve ZJ Grand Cherokee Forum 6 06-14-2004 01:33 PM
