oil pan bolt locations/rebuiding a cammed 4.0 - JeepForum.com
post #1 of 4 Old 04-30-2013, 01:40 PM Thread Starter
eflipzj
i own a 4.0 zj i'm having some difficulties trying to figure out where the oil pan bolts go. and any advice on building a mild 4.0? im new to this site any pointers would be rad.
eflipzj is offline
post #2 of 4 Old 04-30-2013, 02:20 PM
StrateLOSS
IDK if this is a serious question or not.
oil pan bolts obviously go on the pan pan. they bolt into the block, on the bottom.
please don't build an engine if you are serious with this inquiry.
Sent from AutoGuide.com Free App
StrateLOSS is offline
post #3 of 4 Old 04-30-2013, 03:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
well, the 5/16 18 bolts go into their respective holes and the 1/4 20 bolts into the rest. nothing much attaches to the studs so don't worry about those.
ratmonkey is offline
post #4 of 4 Old 06-05-2013, 05:09 PM Thread Starter
eflipzj
in response to StrateLOSS, theres different bolts, one that look like normal bolts and ones with a stud coming off. i didn't know if i made a difference. thats water under the bridge now the engine was running but now theres no spark. thank you ratmonkey.its not the coil, it tested bad at took it back got a new one. the 4.0 has all new plugs wires distributor.
eflipzj is offline
