Oil Loss - JeepForum.com
post #1 of 13 Old 04-06-2005, 07:16 PM Thread Starter
jeeper31
2008 WK
Oil Loss
My 2000 GC seems to be losing oil. Had oil changed about 2200 miles ago and just added about 4 1/2 quarts. I don't see ay dripping and no puddles on the floor. This is not the first timeI had to add oil. Any ideas?
Dan
2000 Jeep Grand Cherokee Limited
8 cyl. (Sold)
2008 Jeep Grand Cherokee Overland (Black)
HEMI Club Member #4
jeeper31 is offline
post #2 of 13 Old 04-06-2005, 09:06 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
You were 4.5 courts low??? That quite a bit. Your oil capacity is only six courts... you were missing quite a bit.
Check to make sure your oil pan plug is tight. Might want to check your oil filter to.
What does your exhaust look like? (smoke)
It is hard to believe that you have lost 4.5 quarts and you don't see any puddles...
Maybe the genious who changed your oil didn't put the right amount in...
Good luck
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #3 of 13 Old 04-06-2005, 09:11 PM Thread Starter
jeeper31
2008 WK
Good luck
Plug and filter are both good. I have been having this problem for awhile. This is not the first time that I have lost oil. Seems to be pretty consistent. I am getting smoke out of the exhaust. Seems white but maybe a bluish tint. Can't tell was looking at it with blacktop background.
Dan
8 cyl. (Sold)
HEMI Club Member #4
jeeper31 is offline
post #4 of 13 Old 04-06-2005, 09:37 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Man am I am idiot! courts of oil? I think I meant QUARTS!! Wow... I can't believe I did that...
Anyway... that bluish tint you mentioned sounds like your burning it... How is your engine running? I'm surprised that something hasn't happened from such a low oil level.
So it has happened before with this much loss of oil?
And your SURE nothing is on the ground or on other engine components... It amazes me that this many QUARTS (there I got it right ) are missing with no real sign of where it is going!
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #5 of 13 Old 04-06-2005, 10:25 PM
01grander
Man that really sucks especially something that newish. Sounds like your eventually going to need to get a rebuilt engine or even better bore that one out and put new pistons and seals. With that much being lost im assuming the worst but usually at that point something definetly went wrong with that engine. Sometimes you can get gunk around the piston rings and or other spots but even isuzu troopers which had that problem w/ not enough oil drainers? only burned 1-2 quarts every 1000. The problem w/ that much being burned off is that it usually starts effecting everything else and soon you have lots to be fixing. Thats just my experience w/ my first car but i hope that its nothing bad. Maybe try some seafoam or mopar cleaner to clean the pistons if their built up and gunk is blocking the oil from where its supposed to be draining. If you suspected it being a blue color to it then its definetly burning oil i know from experience w/ my first POC hyundai!
01 Grand Cherokee Laredo 4.0
245/75r16's w/ 2" of lift
ARB and Surco roof rack
Plenty of Hellas.
01grander is offline
post #6 of 13 Old 04-07-2005, 11:29 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Blue/black/dark gray smoke = burning oil
Large plumes of black smoke under acceleration can be caused from worn piston rings and elliptical cylinder wall profile instead of a parallel profile.
White smoke = burning water/anti-freeze: and many times one can smell a sweet scent from the exhaust. The sweet scent will be the ethylene glycol. This is usually a blown head gasket.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 13 Old 04-07-2005, 09:15 PM Thread Starter
jeeper31
2008 WK
I did notice water dripping out of the exhaust. Does this mean anything?
Dan
8 cyl. (Sold)
HEMI Club Member #4
jeeper31 is offline
post #8 of 13 Old 04-07-2005, 09:28 PM
dougy147
I would just double check and make sure you don't have a double gasket on your oil filter.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #9 of 13 Old 04-08-2005, 07:13 PM Thread Starter
jeeper31
2008 WK
What's the best way to check...Change oil? I don't think that is tit though. I have changed the oil many times since theproblem started. The last oil change the mechanic said the filter was leaking. I assume he would check for a double gasket.
Dan
8 cyl. (Sold)
HEMI Club Member #4
jeeper31 is offline
post #10 of 13 Old 04-08-2005, 09:06 PM
dougy147
I misunderstood, I thought the problem just started with the last oil change. If you want to check it though, take off the oil filter, there should be 1 rubber gasket either stuck in the filter, or possibly stuck to the filter housing, if there is one on both you have found your problem.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
post #11 of 13 Old 04-09-2005, 07:35 AM
greasefingers
1994 ZJ
Water is a side product of combustion and is always present. The vapor condenses as it cools in the exhaust and drips out the weep hole at the bottom of the muffler and at the tail pipe. No worries.
If you simply plug a spark plug and see if it is oily-wet, then this would eliminate the possibility of the piston rings being bad.
Cheers Steve
post #12 of 13 Old 04-09-2005, 08:54 PM Thread Starter
jeeper31
2008 WK
Changed plugs pretty recetnly and seemed ok.
Dan
8 cyl. (Sold)
HEMI Club Member #4
jeeper31 is offline
post #13 of 13 Old 04-09-2005, 09:02 PM
01grander
Well i mean it seems like you clearly burning it up but id take it by a mechanic to see if its an easy fix or what. 4.5 quarts just doesnt disapear and nothings leaking so you must be burning it, all you can do is hope for the best.
Plenty of Hellas.
loss of power dirtneverhurt ZJ Grand Cherokee Forum 0 07-25-2008 05:17 PM
V8 Oil Pressure Loss Hellfire82 ZJ Grand Cherokee Forum 8 02-26-2008 09:22 AM
why the 5 hp loss? 96grandcherokee ZJ Grand Cherokee Forum 11 09-06-2005 08:38 PM
loss of oil? nineseventhree ZJ Grand Cherokee Forum 9 06-10-2003 02:34 PM
help please! I'm at a loss. uwgKA ZJ Grand Cherokee Forum 5 07-19-2002 01:44 PM
