Oil Level Issues - JeepForum.com
post #1 of 9 Old 07-05-2007, 01:31 PM Thread Starter
cj8lvr
1982 CJ8
Oil Level Issues
Alrighty folks, got a question for ya'll.
On my 4.7L 2000 WJ:
Changed the oil and filter yesterday.
I added 6 quarts of oil and a new filter.
Cranked it, let it run a minute or two and watched untill the oil pressure came up to normal. Checked the oil and it was exactly at the "Full" mark on the dipstick.
Drove it to work today about 7 miles. It sat there for about 30 minutes and I went out and checked it. It's about 1/2" OVER the "Full" mark. What the heck?
Should I drain it some or just forget about it? I know overfilling can be bad with some engines. Anybody else had this happen to them?
2001 Jeep WJ Limited 4.7L
2 1982 CJ-8 Jeep Scramblers
1951 Willy VJ Jeepster
cj8lvr is offline
post #2 of 9 Old 07-05-2007, 01:35 PM
Yardman Harry
O
Yardman Harry's Avatar
The V8s should only take 5 quarts...
I hear that you can run your engine with at most a quart over without having any problems, but I wouldnt risk it. I would most definitely drain it.
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 9 Old 07-05-2007, 02:55 PM
CoolHunting
Harry
That's incorrect! The WJ V8's and I6's take 6 quarts.
cj8lvr, the 30 minute wait just let some of the oil which was drawn up in the engine drain back down to the oil pan. Your seeing exactly what you should be seeing.
Ken
'01 WJ Laredo - 4.7L, QD, UC, GY Wrangler SA 245/65/17 tires, MX6 shocks, Stillen rotors (F/R) and MM pads, Addco F/R Sway Bars
CoolHunting is offline
post #4 of 9 Old 07-05-2007, 03:16 PM
Yardman Harry
O
well... thats what i heard....
Hunter Green
White
~Junked~
post #5 of 9 Old 07-05-2007, 03:18 PM
UUJ1
For the record... mine takes 5 1/2 qrts. And it's at the correct fill line.
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #6 of 9 Old 07-05-2007, 03:47 PM Thread Starter
cj8lvr
1982 CJ8
That's what I was thinking... 5 1/2 quarts would put it right on the money.
So drain or not to drain?
I know some drained down in that 30 minute time period, but after draining - it should read "Full" in my mind.
My main question = has anybody else seen a reading beyond the "Full" mark with 6 quarts?
cj8lvr is offline
post #7 of 9 Old 07-05-2007, 04:54 PM
CoolHunting
Well, I'm confident in my response, however, the best thing anyone could do in this case is to look up the answer in their vehicle's owners manual. I would recommend you do this also to: 1) go to the source for the information 2) to put your mind at ease.
And yes! My jeep's oil level reads exactly as yours does (I just changed it last week!)
Ken
post #8 of 9 Old 07-05-2007, 05:02 PM
skain8
skain8's Avatar
6 qts. with new filter on the 4.7L. No need to drain any oil. Don't overthink things.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #9 of 9 Old 07-05-2007, 05:02 PM
UUJ1
The manual says 6, I'm sure your 1/2 quart over won't hurt anything. If you wanted to be safe... you could just drain the 1/2 out and be done... then you'll know for sure you're all right. IMO, I'd rather be a hair ( and I do mean 1HAIR) under, than 1/2 quart over!
'99 4.7 WJ,
UUJ1 is offline
Level Kit NewJeepFever ZJ Grand Cherokee Forum 17 09-25-2008 11:42 AM
ZJ Not Level Steve98 ZJ Grand Cherokee Forum 5 07-27-2007 11:07 PM
Oil level LOW! coolest_Stan ZJ Grand Cherokee Forum 60 02-14-2006 05:05 PM
zj oil level. Derek33 ZJ Grand Cherokee Forum 10 05-24-2005 08:51 PM
ATF level automan25 ZJ Grand Cherokee Forum 6 12-01-2003 07:03 PM
