Oil leak + pressure drop - JeepForum.com
post #1 of 9 Old 07-20-2011, 08:04 AM Thread Starter
mpzj
So I noticed a small oil puddle under my jeep recently and i started looking around but couldn't find where the leak was coming from. I know its not from the filter or the drain plug. Also as I drove and the oil started to heat up, I lost some oil pressure. It usually stays pretty constant around 40psi but it drops to about 30-35. Every now and again I add some oil just to make sure that I'm in the safe zone.
Any Ideas?
mpzj is offline
post #2 of 9 Old 07-20-2011, 12:47 PM
frank21054
Sending unit might need to be replaced. I recently changed the oil and added an oil treatment additive. Pressure went from above 40 to about 2; 10 days later. Replaced the sending unit, and went back to normal.
frank21054 is offline
post #3 of 9 Old 07-26-2011, 06:09 PM Thread Starter
mpzj
Yeah It isnt dropping much and there is a leak somewhere because i see oil on the ground.
mpzj is offline
post #4 of 9 Old 07-26-2011, 06:38 PM
cappedup
If I could jump onboard this thread a sec.
My oil pressure has pretty much been a stable 20 since I bought the 96ZJ 4.0 GC Limited about 5 months ago.
Its done 250k and always had regular servicing.
It doesnt 'lose' oil as such, but there are 'weepy' bits that dont concern me too much. The dipstick level hasnt dropped much between changes.
It does a regular 15 miles twice a day, not much else.
is there a desired oil pressure reading for all Jeeps, or does it vary dependng on milage, wear etc?
cappedup is offline
post #5 of 9 Old 07-26-2011, 06:57 PM
General_Jeep
1994 ZJ
Honestly it sounds like your Oil pressure sending unit burst. While I had my trans. dropped I decided to change it because that's where my oil leak was from. Its located behind the the distributor so with out the trans being dropped I'm going to guarantee you its a PITA to get out.
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #6 of 9 Old 07-27-2011, 12:44 PM
Midnightluckey
Not with the correct socket. Took me like 10 min from start to finish. Go to vatozone. They sell a special $6 socket for it.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #7 of 9 Old 07-29-2011, 07:28 AM
cappedup
So, what do you fellas think? Is a reading of around 20 (psi?) acceptable? Are there upper and lower values for oil pressure?
You know, i've never had a vehicle with a oil pressure gauge, only low pressure light. If its not there, you can't worry about it!
Thanks.
cappedup is offline
post #8 of 9 Old 07-29-2011, 08:03 AM
TheHalfWit
Thanks.
Jeep specs say 13psi for 600 rpm, and when mines warmed up it usually idles around 17psi on that gauge but that gauge has a reputation for being inaccurate compared to a mechanical gauge.
75PSI is the max safe oil pressure, 13PSI is the lowest.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #9 of 9 Old 07-29-2011, 09:26 AM
cappedup
Ace, thanks halfwit. The OP says his is usually 40, so got me thinking.
Cheers.
cappedup is offline
Oil pressure guage drop question Darkhorse192 ZJ Grand Cherokee Forum 5 11-11-2010 02:53 PM
how to drop the headliner ? leak in A frame pillar billybob123 WK Grand Cherokee & XK Commander Forum 2 04-29-2010 06:34 PM
why does oil pressure drop when put in drive spikeystrip ZJ Grand Cherokee Forum 2 08-18-2009 09:08 PM
Oil pressure drop at stop egaus ZJ Grand Cherokee Forum 1 09-18-2007 02:36 PM
Oil Pressure Drop after driving lawdogg ZJ Grand Cherokee Forum 12 09-13-2007 12:21 PM
