Oil Leak - Main seal cost$ - JeepForum.com
post #1 of 8 Old 03-23-2008, 06:52 PM Thread Starter
JKot55
Does anyone know how much it would cost to have the main seal replaced. I get a 1 to 2 inch spot on the ground right under area where trans and engine come together.
1995 5.2ltr 106000 miles.
Thank you
JK
JKot55 is offline
post #2 of 8 Old 03-23-2008, 06:54 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
the gal next door to me got main seal done in her durango for like 800$, but IMO, she got ripped, then again, i do all my own work.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 8 Old 03-23-2008, 08:04 PM
gomes512
1994 ZJ
The lowest I have seen it done for was < $500 in my area by a diesel truck shop.
I helped a buddy change his on his driveway. Never doing it again unless the Jeep is on a hyd. lift.
I have noticed that the price is strongly influenced by the experience of the people in the garage. Those that have dealt with trucks often tend to charge a few bones less in price.
This is the guide writeup we used to help us (if you want to know how its done):
http://www.mallcrawlin.com/forum/showthread.php?t=2881
gomes512 is offline
post #4 of 8 Old 03-23-2008, 10:17 PM
Upside
You may want to check your oil pressure sender for leaks. My oil pressure sender and intake manifold gasket were allowing oil to leak down the back side of the engine. It looked like a rear main seal so I pulled the flex plate cover and didn't see any leakage from the rear main seal area.
Pulling the flex plate cover isn't hard and you can check the seal that way. Replacement of the seal itself takes probably 6 hours if you haven't done it before, the 5.2 uses a 2 piece seal.
Upside is offline
post #5 of 8 Old 03-24-2008, 05:35 PM Thread Starter
JKot55
Great info. Thank you all. Upside, just wondering about the oil pressure sender; could this leak and still give a proer pressure reading?
Thanks again.
JK
JKot55 is offline
post #6 of 8 Old 03-24-2008, 05:40 PM
2002GC
My rear seal also leaks, and it will leak until I get rid of it, oil is cheap just keep filling it up as needed.
2002 Grand Cherokee I-6 4.0 215,500 miles
1979 280CE Mercedes 215,800 miles
1976 300D Mercedes 183,000 miles
2002GC is offline
post #7 of 8 Old 03-24-2008, 09:24 PM Thread Starter
JKot55
I guess it's common. Not sure I ever had a car (American made) that didn't develop this leak.
JKot55 is offline
post #8 of 8 Old 03-24-2008, 09:30 PM
IronManVa
I AM IRON MAN
IronManVa's Avatar
I asked this awhile back, thought I would share my thread. I went with the Lucas rear main it worked pretty good. I sold the jeep about a month later so I do know what came of it.
http://www.jeepforum.com/forum/f13/95-zj-5-2-rear-main-seal-433043/
2004 Overland 4" KOR/IRO Long Arms
2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system
1995 Jeep Orvis 4.0 3" Rancho
Virginia Beach ...
Off season Jeeper Deals
IronManVa is offline
Rear Main Seal Leak!!! ThaPharCyd ZJ Grand Cherokee Forum 11 11-11-2007 02:44 PM
rear main seal leak avbcon12 ZJ Grand Cherokee Forum 5 11-05-2007 03:59 PM
Rear main seal leak Drunet ZJ Grand Cherokee Forum 8 07-12-2006 09:25 PM
Rear Main Seal Leak? gdupjeep ZJ Grand Cherokee Forum 14 11-09-2005 12:33 AM
Rear Main Seal Leak - Fix or not? Burly ZJ Grand Cherokee Forum 12 08-10-2005 08:36 AM
