Oil Leak - JeepForum.com
post #1 of 3 Old 10-23-2009, 02:31 PM Thread Starter
frankie_b11
Oil Leak
hey Gang,
I was doing an oil change and I noticed oil on the back of my filter. I have noticed the Jeep leaking a little drip here and there and oil spray underneath.
I origionally thought rear main seal on the leak but I was wondering would the adapter leak enough to get oil spray on the oil pan or do I now have 2 leaks?
97 zj 156,000 miles
Thanks
frankie_b11 is offline
post #2 of 3 Old 10-25-2009, 10:36 PM Thread Starter
frankie_b11
Anyone out there?
post #3 of 3 Old 10-25-2009, 10:44 PM
Reiver
Reiver's Avatar
are you sure the old filter is torqued all the way? I changed my oil the other day and the filter is really hard to get at (mine is not lifted) since it's behind 3 bars. I thought I had torqued it all the way...what a difference a millimeter gap will make....several hours cleaning the driveway with 5 gallons of oil soak. I've never had to tq the filter that much on any of the 20-25 previous cars I've owned, although this one is much harder to get at...make sure to oil the filter before installing the new one to create a good seal
I'm building muscle in not often used areas since I have to do yoga positions on a lot of the maintenance on the WJ 4.7HO
2003 Black Grand Cherokee Limited 4.7HO
Reiver is offline
Anybody ever used Bar's Leak or Alumaseal radiator stop leak? scarthearmada6 ZJ Grand Cherokee Forum 23 05-02-2014 03:10 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 04:58 PM
2003 JGC I6 codes 442 medium leak and 455 large leak samsdad ZJ Grand Cherokee Forum 0 08-28-2007 11:17 AM
fron driveshaft join leak and pinion seal leak. GRDCHRKE555 ZJ Grand Cherokee Forum 1 12-12-2006 08:10 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 09:42 AM
