Oil leak on 2002 Grand Cherokee - JeepForum.com
post #1 of 3 Old 01-29-2010, 01:21 PM Thread Starter
Mike D
I recently purchased a 2002 Grand Cherokee with the 4.0L 6 cylinder engine. I noticed the passenger side of the engine was very dirty and greasy. I cleaned the engine and determined the oil leak was coming from the valve cover gasket. I replaced the valve cover gasket and after about 2 weeks I inspected the passenger side of the engine and there was a thin film of oil on the side of it. I determined the oil leak was coming from the area where the head bolts to the block. There is no other leaks of any kind. Anyone have this problem and corrected it.
Thanks,
Mike
Mike D is offline
post #2 of 3 Old 01-29-2010, 02:01 PM
sdowney717
My 4.0L leaked from the oil filter adapter. The o-rings dry out and shrink.
sdowney717 is offline
post #3 of 3 Old 01-29-2010, 02:13 PM
cmonson
could have been a film from when the oil filter was replaced.
It could also just be your oil filter gasket. It would be VERY hard to leak oil between the head and the block. If you had an oil leak between the head and block, you would most likely also have a coolant leak between the head and the block. If that was the case, you would also have a bad head gasket...
I wouldn't worry about it too much, but monitor it. Oil leaks aren't the end of the world... Where there is an oil leak, there won't be any rust.
I just finished restoring an old camaro that had a bad rear main most of its life. The bottom of the car was drentched in oil. B/C of that, the bottom of the car had absolutely ZERO rust on the bottom side all attributed to an oil leak. I also coat the bottom of my grand cherokee with a small film of oil a couple of times before and during winter. My 10 year old salt belt driven vehicle has ZERO rust on the bottom side where most others that are 10 years old do...
cmonson is offline
2002 2.7td Grand Cherokee(uk) bazzer12 ZJ Grand Cherokee Forum 11 07-11-2008 05:55 PM
2002 Grand Cherokee Limited. avenom ZJ Grand Cherokee Forum 4 02-13-2008 07:18 PM
What does my 2002 grand cherokee have? Edward777 ZJ Grand Cherokee Forum 8 09-23-2007 12:51 AM
Two 2002 Grand Cherokee Issue Grand Joe ZJ Grand Cherokee Forum 1 02-26-2006 06:33 PM
2002 Grand Cherokee Hell Raiser 106 ZJ Grand Cherokee Forum 4 12-06-2005 09:42 AM
