Oil filter help :) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Oil filter help :)
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! BroughAll Bilstein shocks & struts - Lowest Prices Ever and
Unread 02-20-2015, 06:58 AM   #1
Adee
Oil filter help :)
Hi there,
I have just received an oil filter to my beauty.
This is a MANN oil filter. In order to their catalogue I need W920/6 but I have W916/1 - the only difference is colour and Bypass Valve Opening Pressure (see links). And now is THE question: can I use it?
Cheers, Adam
links to both versions:
http://catalog.mann-filter.com/EU/en...lter/W%20916~1
http://catalog.mann-filter.com/EU/en...lter/W%20920~6
Adee is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 10:22 AM   #2
sebian
The black one looks like it should work with your ZJ, but I would call them to clarify since their chart is not very user friendly. The white one does not like Jeep at all, so I would avoid it.
1995 ZJ 5.2L V8 318. 220,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 11:07 AM   #3
XJ93
Wix filter 1085, which is what Jeeps use here in the U.S., crosses to the W920/6
XJ93 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 03:38 PM   #4
Adee
Not WIX WL7188 ?
Unread 02-20-2015, 03:51 PM   #5
Para32
IMHO, the difference in bypass pressure is 13.3 vs 14.7 PSI......negligible.
Most filters have a bypass pressure in the range of approx 14 - 20 PSI
A 1.3 PSI difference is nothing
More important would be the micron size of the filter media in each filter
If its the same, it should not matter which filter you use
Para32 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 04:22 PM   #6
XJ93
WL7188 is the Euro number for a 1085 U.S.
Unread 02-20-2015, 04:31 PM   #7
Adee
Thanks guys To be 100% sure that I have right oil filter I just ordered Wix 1085/WL7188. That MANN W916/1 goes back to the seller
You were very helpful! Cheers!
