Oil Filter Adaptor Removal (my way) - Page 4 - JeepForum.com
post #46 of 138 Old 05-25-2010, 11:20 AM
JesseOR
No, the only O-ring you will need, without an adapter, is on the filter itself.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #47 of 138 Old 05-27-2010, 09:37 AM
trigga
Thanks. Thats what I thought just wanted to make sure.
trigga is offline
post #48 of 138 Old 06-11-2010, 07:27 PM
kymbo1975
great pics.
kymbo1975 is offline
post #49 of 138 Old 12-13-2010, 09:48 AM
melk
Good info. I'm gonna take a crack at mine next oil change.
melk is offline
post #50 of 138 Old 03-20-2011, 11:04 AM
keastland
Added to the list
keastland is offline
post #51 of 138 Old 06-13-2011, 06:14 AM
Wildspear
Did this mod with my wife's 2000 Cherokee (no issues after the mod) and I'll be doing this with my 93Grand Cherokee this weekend.
Mud, it's not just wet dirt.....it's a way of life!
Wildspear is offline
post #52 of 138 Old 06-13-2011, 01:37 PM
TallyZJ
I welded an 18mm hex nut to my oil filter adapter bolt so I could get a large wrench on it. Mine came loose with no problem.
The large o-ring is available from Advance Auto Parts, Car Quest and Oreilley Auto Parts.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #53 of 138 Old 10-25-2011, 07:37 AM
KoreaZJ
1994 ZJ
What if a motor mount breaks?
The engine moves to the side more when the rubber is shot in the mounts.
Would there still be enough clearance without the adapter?
KoreaZJ is offline
post #54 of 138 Old 11-21-2011, 06:44 PM
motordoctor
I replaced my oil filter housing today. Actually I just took it off, transferred the nipple from the housing to the block, pulled the locating pin out of the block and mounted the filter directly to the engine. Not a lot of room but it will fit. You have to hand tighten it, not enough space to get a band style filter wrench in there. I probably would have just put the adapter back on but I didn't have the "O" rings. Thought I might have something at work to put it but nothing was close. I used a T-60 bit that I removed from the socket, put a 12mm ratcheting box end wrench on that. The added leverage came from a 15" Crescent wrench. I would have used a pipe wrench but didn't have any swing room. That sucker was tight!!!!! Used a pair of vice grips to pull the locating pin out. Flushed all the oil off the block and hopefully my oil leak is gone. Keeping my fingers crossed, really don't want to replace the rear main seal........
motordoctor is offline
post #55 of 138 Old 12-16-2011, 10:27 PM
slayercr23
could you damage one of these o-rings by over tighting the oil filter?
slayercr23 is offline
post #56 of 138 Old 12-16-2011, 10:39 PM
sbrunner
Didn't see any one mention doing it how I did. Since there isn't room to get the torx socket and a ratchet in there, I took a punch to my t60 socket so I was left with two pieces. I broke it basically, just punched out the torx portion so it wasn't pressed into the 1/2" drive square section anymore. Then I just used my t60 torx "bit" and a wratcheting wrench to take it off.
sbrunner is offline
post #57 of 138 Old 12-16-2011, 11:32 PM
TheHalfWit
A lot of T60 sockets have an Allen key built into the side.
Sent from my iPod touch using JeepForum
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #58 of 138 Old 12-17-2011, 01:34 AM
KoreaZJ
1994 ZJ
T60 pics?
KoreaZJ is offline
post #59 of 138 Old 12-17-2011, 03:27 AM
TheHalfWit
The socket or the bolt? The socket is this
http://www.sears.com/craftsman-t60-t...p-00934491000P
but you can't see the Allen key I was talking about on that page.
http://www.sears.com/craftsman-t55-t...p-00934490000P
That ones a T55 but it has the Allen key clearly visible. Once you remove the key you can slide the torx bit out of the socket and put a wrench on it.
I don't know who you buy your tools from in South Korea, but most of the name brand sockets have Allen keys on the 1/2" torx sockets.
Calm. C.
post #60 of 138 Old 12-17-2011, 04:47 AM
KoreaZJ
1994 ZJ
Neat, so it's actually designed to come apart and reattach with the set screw?
Local garage might have one I can borrow for the job. Tx.
KoreaZJ is offline
Quick Question!! Back to the WJ 4.0L Fuel filter... Removal?? JonM81 ZJ Grand Cherokee Forum 0 05-01-2009 03:04 PM
3.0 v6 diesel oil filter cap removal tool Roughneck 6zero WK Grand Cherokee & XK Commander Forum 5 01-27-2009 05:07 AM
How I did my oil filter adaptor TslAtticus ZJ Grand Cherokee Forum 4 06-19-2008 02:09 PM
95 ZJ fuel line removal & Oil filter removal Ahardy4 ZJ Grand Cherokee Forum 6 12-02-2007 02:33 PM
Oil Filter Adaptor O-Ring 4.0L 02Lightning ZJ Grand Cherokee Forum 5 06-26-2007 11:46 AM
