01-23-2006, 05:58 PM
#1
Oil Filter Adaptor Removal (my way)
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
01-23-2006, 06:03 PM
#2
???? I thought it was supposed to leak from there.????
When I did mine on the 4.0 I removed a motor mount and jacked the engine up, it was a PITA squared.
Awesome pics. great tips.
Andy
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
[B]Black Jeep Club Member Ver. 2 #51[/B]
01-23-2006, 06:06 PM
#3
Nice job dude
I'm so glad V8s don't have this problem
01-23-2006, 06:22 PM
#4
GSMW!
True, I'm glad the V8's are not notorious for this, but the plenum gasket isn't much better
Grease, I take it you cannot find the wrenchin' Lizard?
01-23-2006, 06:29 PM
#5
Nice work. I see you found another way to get it off. I used a pipe wrench as well but not in quite the same way.
Its been a while since I changed my three seals out and the leaking is very muched reduced however I am not sure it is completely gone. I still get a small spot of oil on the ground but it is about 1/8 the size it was before. I suspect that it may simply be from the leftover residue from oil leaking on the lower part of the block that is dripping off a hot engine. I need to use degreaser to clean up the lower part of the engine to see if I have another leak somewhere.
Dan
Traded 8/9/07
[SIZE=1]Black 94 ZJ Laredo 4.0L 42RE/NP231 Command Trac
Sylvania Silverstars, Alpine CD Head Unit, Pioneer 3-Ways in the Doors, Blacked Out Grill, Kolak Exhaust, Clear Corners, Bilstein Shocks, Gas Tank Skid, Rear Hitch, Hitch Wiring, TC Skid, Hellwig RSB, Military FSB, Brembo Front Rotors, OME SS, B&M Supercooler, RE Tie Rod, Limited Power Leather Seats, 30x9.5 Toyo Open Country ATs, Optima Red Top
Next Mods: Upgrade Battery Cables, Sliders, Black Steelies, 3" Lift, Rear Locker, Bumper, HO Alternator, Winch, Driving Lights[/SIZE]
01-23-2006, 06:41 PM
#6
No he went to Florida for the winter, however these two guys showed up!
Cheers Steve
01-23-2006, 06:44 PM
#7
Oh I have lots of leaks…lets see engine main rear seal, power steering pump, and valve cover. I just attack them one at a time, when I get a chance and when the weather is warm.
Cheers Steve
01-23-2006, 07:05 PM
#8
I just did mine power steering pump, water pump and radiator a month ago or so.
Wasn't too bad but let me tell you that bypass hose is f****** PITA
Now I'm gathering all part to do an electric fan conversion and I think I just got a killer deal on a drive shaft. I think it will keep me busy for a month or so
01-23-2006, 07:25 PM
#9
GSMW!
Zaq, I replaced my bypass hose while I was reinstalling the intake before I put on the pulley mounting bracket. Keep you eye's open for a Taurus E-fan swap this Saturday. I started it while I had the fan and fan shroud off, I'll be sure to post up the pics, mounting, and relays.  What fan are you using?
Grease, I like the new wrenching crew!
01-23-2006, 07:42 PM
#10
It looks like when you put this back together you could point the filter any direction you want. Is this possible?
1995 Jeep Grand Cherokee Limited 4.0L NP249 Transfer Case 196,000 miles
2002 F150 Lightning 385 hp
1969 Mustang Mach 1 428cj 4-speed 3:89 gears
01-23-2006, 08:04 PM
#11
Taurus 3.8L. I'm tapping into my thermostat housing with a temperature probe (to get temp. as accurate as possible) and using adjustable thermostat 175-230.
I think I'll use high speed for cooling and low speed for AC. I'm still thinking about it. But I have whole thing worked out in my head so if you need any help let me know. I'm an annoying perfectionist when it comes to electrical part. yada yada yada
PS . Total thread hijack
01-23-2006, 08:17 PM
#12
There is a locating pin on the engine block that gets oriented into the adaptor. The slot for the pin can be seen at the 9:00 o’clock position on the picture below. So the oil filter can only go back on one way. But that was very perceptive of you!
Cheers Steve
01-23-2006, 08:21 PM
#13
Grease, you finally cleaned out you garage?
08-12-2006, 04:24 PM
#14
Ok i spent long enough this afternoon trying everything to get this damn thing off to replace these 3 seals with no luck!
I'm going to go smack my head against the wall for about 10 minutes - brb
'95 ZJ 4.0L I6 All Stock Baby!
08-12-2006, 06:06 PM
#15
They either come off easy or they take you for a ride. One of the problems is leverage. You just can’t enough body weight behind the wrench. I finally ended up using the pipe wrench configuration in one of the photos above along with a box wrench to give me the leverage needed to break her free. It really pissed me off. It looks so simple but ......
Cheers Steve
