-   -   Oil Filter Adaptor Removal (my way) (http://www.jeepforum.com/forum/f13/oil-filter-adaptor-removal-my-way-231507/)
greasefingers 01-23-2006 06:58 PM
The oil filter adaptor is famous for leaking. Surprising enough removing it was a PITA for me. No room to work on it. The wrench needed to remove the central bolt on mine was a T60. I bought a T60 driver to fit my breaker-bar. This did not work. Funny thing however is that a 3/8” Hex L-key fits inside the T60 female part. The T60 wrench does have more surface area contact so use it if you have one. I could not remove this stubborn bolt with the T60 or the hex key because they would flex, so I placed a pipe wrench on the outer edge of the bolt shoulder and used an open-end wrench on it for more leverage. It actually took me about an hour to remove ONE bolt, using three different methods. Try to remove it with the correct tool first before using a pipe wrench. Mine has not been changed before and after almost 12 years, it was very stubborn.
The dealer sells a sealing kit that contains three O-rings for $ 3.83. I tried Pep-boys & AutoZone first with no avail. The largest of the three O-rings had become very hard and nonflexible. No wonder it leaked and the colder it was outside the more it leaked.
http://i3.photobucket.com/albums/y59...ingers/T60.jpg
http://i3.photobucket.com/albums/y59...ers/HexKey.jpg
http://i3.photobucket.com/albums/y59...ngers/Pipe.jpg
http://i3.photobucket.com/albums/y59...s/Oringkit.jpg
http://i3.photobucket.com/albums/y59...ngers/Kit2.jpg
jeepholic 01-23-2006 07:03 PM
???? I thought it was supposed to leak from there.????
When I did mine on the 4.0 I removed a motor mount and jacked the engine up, it was a PITA squared.
Awesome pics. great tips.
Andy
zaq123 01-23-2006 07:06 PM
Nice job dude:thumbsup:
I'm so glad V8s don't have this problem
EMTimZJ 01-23-2006 07:22 PM
True, I'm glad the V8's are not notorious for this, but the plenum gasket isn't much better:p
Grease, I take it you cannot find the wrenchin' Lizard?
dpierson 01-23-2006 07:29 PM
Nice work. I see you found another way to get it off. I used a pipe wrench as well but not in quite the same way.
Its been a while since I changed my three seals out and the leaking is very muched reduced however I am not sure it is completely gone. I still get a small spot of oil on the ground but it is about 1/8 the size it was before. I suspect that it may simply be from the leftover residue from oil leaking on the lower part of the block that is dripping off a hot engine. I need to use degreaser to clean up the lower part of the engine to see if I have another leak somewhere.
greasefingers 01-23-2006 07:41 PM
No he went to Florida for the winter, however these two guys showed up!
http://i3.photobucket.com/albums/y59...s/spongbob.jpg
greasefingers 01-23-2006 07:44 PM
Oh I have lots of leaks…lets see engine main rear seal, power steering pump, and valve cover. I just attack them one at a time, when I get a chance and when the weather is warm.
zaq123 01-23-2006 08:05 PM
I just did mine power steering pump, water pump and radiator a month ago or so.
Wasn't too bad but let me tell you that bypass hose is f****** PITA
Now I'm gathering all part to do an electric fan conversion and I think I just got a killer deal on a drive shaft. I think it will keep me busy for a month or so
EMTimZJ 01-23-2006 08:25 PM
Zaq, I replaced my bypass hose while I was reinstalling the intake before I put on the pulley mounting bracket. Keep you eye's open for a Taurus E-fan swap this Saturday. I started it while I had the fan and fan shroud off, I'll be sure to post up the pics, mounting, and relays.:thumbsup: What fan are you using?:OffTopic:
Grease, I like the new wrenching crew!
02Lightning 01-23-2006 08:42 PM
It looks like when you put this back together you could point the filter any direction you want. Is this possible?
zaq123 01-23-2006 09:04 PM
Taurus 3.8L. I'm tapping into my thermostat housing with a temperature probe (to get temp. as accurate as possible) and using adjustable thermostat 175-230.
I think I'll use high speed for cooling and low speed for AC. I'm still thinking about it. But I have whole thing worked out in my head so if you need any help let me know. I'm an annoying perfectionist when it comes to electrical part. yada yada yada
PS . Total thread hijack
greasefingers 01-23-2006 09:17 PM
There is a locating pin on the engine block that gets oriented into the adaptor. The slot for the pin can be seen at the 9:00 o’clock position on the picture below. So the oil filter can only go back on one way. But that was very perceptive of you!
http://i3.photobucket.com/albums/y59...012_edited.jpg
zaq123 01-23-2006 09:21 PM
Grease, you finally cleaned out you garage? :)
Drunet 08-12-2006 05:24 PM
Ok i spent long enough this afternoon trying everything to get this damn thing off to replace these 3 seals with no luck!
I'm going to go smack my head against the wall for about 10 minutes - brb
greasefingers 08-12-2006 07:06 PM
They either come off easy or they take you for a ride. One of the problems is leverage. You just can’t enough body weight behind the wrench. I finally ended up using the pipe wrench configuration in one of the photos above along with a box wrench to give me the leverage needed to break her free. It really pissed me off. It looks so simple but ......
The time now is 10:19 PM.
