oil filter. - Page 3 - JeepForum.com
post #31 of 38 Old 06-11-2013, 12:10 PM
NewtoZJ
Currently using the Amsoil EA Filter and 10W30 Signature Series.
NewtoZJ is online now
post #32 of 38 Old 06-11-2013, 01:43 PM
tucsonzj
Originally Posted by kodenz View Post
Almost Everyone I have ever know has sworn by fram filters....
I believe that's due to their business model though.
One person warned me about them and told me to never go near them and if you check out that comparison I think I know why now.
After some googlin I have found people accusing their fram filters for causing an engine knock and falling apart within 3000miles.
No offense to those of you that use fram! Maybe I'm just super paranoid and they were just campfire ghost stories that scared me!
sent from: somewhere
I've never seen a a fram filter fall apart. you'll always find people complain about something, most of it's BS. Or they don't know how to work on cars haha.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #33 of 38 Old 06-11-2013, 09:24 PM
jeepyard
I use the mopar, wix and purealator filters on all my mopars. The wix or mopar filters usually goes on my 69 charger which uses the same filter as the 4.0's and the magnum 5.2's and 5.9's. I use the others for the daily drivers since the oil gets changed on them a lot more often than the charger get it since it sits most of the time and gets driven on weekend when it isn't raining which is hardly ever lately!!
jeepyard is offline
post #34 of 38 Old 06-11-2013, 09:33 PM
pcoplin
I use whatever is on sale, although I do shy away from Fram. I change them frequently, though. Usually Napa Silver, STP, or Motorcraft. I use the larger Ford filter on all my Jeeps.
FullStack MotorSports
pcoplin is offline
post #35 of 38 Old 06-11-2013, 09:38 PM
AmishFury
i've personally seen one and seen photos/video of another... this is of course out of how many frams on the road?
both had the same issue... the leaf spring failed and the internals were loose inside the can... no engine boom, some noises when it happened maybe but no boom... and yes i'm aware many other brands also use leaf springs instead of a coil... maybe that's why ZJ people like wix so much we know the superiority of coils
AmishFury is offline
post #36 of 38 Old 06-12-2013, 12:13 AM
jnicewan
Cut some of them apart, cut very close to the end cap/flange so you dont cut the filter and you will see why Fram is crap. The ends of the filter media are flimsy cardboard. I have seen quite a few of them that have failed and starting coming apart, two that I know of that ruined engines. In fact the not only a problem with cardboard coming apart, the check valves have been known to come apart and block oil passages too.
Just google "fram oil filter failure". Fram filters have been the only brand I have heard of where OEM's have been known deny warranty claims from lube problems. I know there are multiple levels of fram filters, that in itself raises a flag with me, maybe the higher end ones are better?
I have cut apart many different brand filters and most of them are built decent except a few, the ones that I remember were crap are STP, microguard, firestone, fram and a few other cheaper brands. Brands like purolator, mopar, motorcraft, a/c delco, mobil, wix, fleetguard, bosch were all good from what I saw.
jnicewan is offline
post #37 of 38 Old 06-12-2013, 08:55 AM
zander21510
The oreiley by my parents house once had a fram and a wix side by side cut clean in half. The fram was just sad, had way less filter media, looked like cardboard, not made well while the wix was packed with filter media and held by metal and nice and clean.
I've always heard the cheapest fram is what you need to stay away from and that the higher tiers are fine.
zander21510 is offline
post #38 of 38 Old 06-12-2013, 02:43 PM
eagsc7
1994 ZJ
Guess I'm cutting mine apart just for kicks when it gets changed..
eagsc7 is offline
