Oil emulsion in cooling water header tank - JeepForum.com
post #1 of 11 Old 02-14-2008, 05:40 AM Thread Starter
derbydalesman
2001 FSJ Cherokee
I am experiencing a substantial build up of oily emulsion in the header expansion tank of the cooling system of my Grand Cherokee Ltd 3.1 CRD 2001 - any answers as to what it may be, and what needs doing?
derbydalesman is offline
post #2 of 11 Old 02-14-2008, 07:08 AM
bluerubicon06
Possibly a blown head gasket, how is the oil in the crankcase? Is it a little watery or foamy? Just my thoughts this early in the morning
Do it today! You never know about tomorrow
bluerubicon06 is offline
post #3 of 11 Old 02-14-2008, 08:06 AM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Could very well be a faulty head gasket.
Tint bit of oil coming into the cooling passages.
you might not see anything in the oil, as they are different passages.
You can doo a coolant flush to eliminate other possibilities.
SpeedyCat3 is offline
post #4 of 11 Old 02-14-2008, 08:25 AM
bluerubicon06
depends on where the blow out is in the gasket if that is the problem, under the head all the passages are exposed to each other till sealed by the gasket. He may even experiance a miss fire in the engine.
I don't believe he mentioned how many mile are on the motor even though a gasket can blow at any time!
He can also check his spark plugs for excess oil or run a compression check.
Blown head gaskets can affect all sorts of things. Some things may not show up to extremes till later.
It is good he found the trace this early as he can pursue the issue soon before he gets stranded some where.
Heck it mat be nothing at all
post #5 of 11 Old 02-14-2008, 08:29 AM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
That is why I said "might not".
post #6 of 11 Old 02-14-2008, 08:38 AM
bluerubicon06
we agree
post #7 of 11 Old 02-14-2008, 11:11 AM Thread Starter
derbydalesman
2001 FSJ Cherokee
Thanks for all your replies - a mechanic here in England has stated that the car had an oil leak in the transmission cooling system (same coolant as engine??) and that is where the oil is coming from - the transmission cooler was replaced, but left residual oil in the system that is now coming to the top - does that make sense? You will gather that I am a novice with regard to mechanics, but love the car, it is awesome (2001 Grand Cherokee Ltd 60th Anniversary 3.1 CRD) Further help appreciated!
post #8 of 11 Old 02-14-2008, 11:51 AM
bluerubicon06
sounds possible!! Oil floats on water so it should come to the top sooner or later. Specially if the trans and motor are using the same cooling system fluids. Glad it wasn't a blown head gasket. They are on the expensive side if done by someone other than yourself
post #9 of 11 Old 02-14-2008, 05:35 PM
Aceladriver
The mechanic must have meant the transmission cooler inside the radiator cracked and leaked into the radiator coolant.
The transmission lines runs into the side tank on the radiator where there is a cooler that transfers the ATF heat to the coolant and eliminates it through the radiator. That is the only place the two come close to each other.
EDIT: The radiator would had to have been replaced to fix this problem. How long ago was this supposed to have been done and does the radiator look new/clean? Might want to check your tranny fluid condition too to make sure it isn't pink or frothy.
Keep an eye on it though in case that isn't the problem.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #10 of 11 Old 02-23-2008, 07:28 PM
Carl40
Hi all. Exactly the same problem with my Granny 3.1TD at 74000 miles. Head Gasket replaced. Fortunately none of the cylinder heads was damaged. it was actually the first time that I heard that my car has 5 different cylinder heads...ahhhh. Hell of a work. Might get it back on Monday. Cost....ca 1000 Pounds.
Carl40 is offline
post #11 of 11 Old 02-24-2008, 10:20 AM
Aceladriver
It will make a big difference whether it is leftover from the ATF cooler problem or a new problem with a head gasket etc.
First you need to determine which it is. I would lean towards it having a pinkish tinge if it is actually the leftover ATF. If it has a brownish tinge I'd lean towards it being engine oil.
Also look for coolant (or an area clean of motor oil) at the bottom of the engine oil dipstick which should also give it an abnormally high oil level too.
cooling system problems , water pump and thermostat replaced . no heat. natesxj ZJ Grand Cherokee Forum 4 10-25-2009 09:49 AM
OIL in WATER/COOLANT top up TANK? norm67 ZJ Grand Cherokee Forum 17 06-03-2009 10:48 AM
Fox 2.0 Emulsion shocks for wj ?Doetsch tech 8000 prerunner shocks ? genislav ronen ZJ Grand Cherokee Forum 2 06-04-2008 09:31 PM
Oil Emulsion is it normal? squidward ZJ Grand Cherokee Forum 7 02-16-2005 08:59 AM
water coming in a wj doors when going through water off road mikkjroverland WJ Grand Cherokee Forum 1 10-05-2003 08:04 PM
