Oil in Cylinders? - JeepForum.com
post #1 of 2 Old 12-14-2011, 12:49 PM Thread Starter
Degra101
Oil in Cylinders?
I know in old engines (chevy 350's and such) you can pull the plugs (or just put in intake) just a little motor oil to lube up the cylinders, I know its safe in the old ones but what if I did that in my 4.0 ? Would it be safe you think.
What I used to do with the old ones is pull all the plugs and put just a little motor oil in each hole and let it sit over night. Then start it up and burn off the oil and it helped the top rings. Would this be something I would want to do on my 4.0 Jeep ?
Degra101 is offline
post #2 of 2 Old 12-14-2011, 01:18 PM
LordHobbit
There will be no problem putting oil in the spark plugs holes.
Just remember to reinstall the spark plugs, or you won't be able to start the engine.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
Firing only on 3 cylinders need some Guru Help. MichaelZJ ZJ Grand Cherokee Forum 14 07-01-2015 06:45 AM
Running rough/5 cylinders???? JesseOR ZJ Grand Cherokee Forum 10 04-26-2010 07:01 PM
Multiple Misfire in all cylinders? samnthanicolexo ZJ Grand Cherokee Forum 1 10-13-2009 08:42 PM
HELP! Not firing on all cylinders? Eldoradoman ZJ Grand Cherokee Forum 60 08-20-2009 10:19 PM
Help please, need diagram for cylinders 5.2 v8 95 Firefox0119 ZJ Grand Cherokee Forum 2 07-03-2009 03:46 PM
