Oil change question - JeepForum.com
post #1 of 11 Old 09-25-2009, 03:52 PM Thread Starter
tirus89
Oil change question
Now that I'm on a campus where I don't need to drive my jeep as much as before, would it be in my favor to change the oil at a different interval other than the 3000 mile mark. I only drive it about 1-2 times a week for a grand total of 6-7 miles, 10 miles max. I'm just weirded out that because the oil sits so long it wouldnt retain some protection properties. Thanks for the help.
tirus89 is offline
post #2 of 11 Old 09-25-2009, 04:07 PM
the88thpianoman
2003 WJ
Depending on your mileage or other factors that may make you more or less prone to oil leaks, you may want to start using synthetic or blend oil. You won't have to worry about it breaking down over time. A good synthetic oil will easily last a year on low miles.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 11 Old 09-25-2009, 04:22 PM
Deezelweazel
Just have a look in your manual. There is a description of shorter oil change habits: of low mileage,short range driving, driving in desert areas, trailer tow, long idle, high speed, off road driving.
If you want to go on the safe side...
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline
post #4 of 11 Old 09-25-2009, 04:25 PM
sandman
regardless of the mileage i would change it atleast every 3-4 months.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 11 Old 09-25-2009, 04:44 PM
LordHobbit
Short trips are harder on engines than long trips. Stick with 3000 miles at most between changes.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 11 Old 09-25-2009, 07:01 PM
the88thpianoman
2003 WJ
He's not talking about short trips, he's talking about very little overall driving. Changing it every 3000 would make for a very long duration of changes.
post #7 of 11 Old 09-25-2009, 07:24 PM Thread Starter
tirus89
I think, actually I dont know what I'm going to do. I kinda want more responces...
tirus89 is offline
post #8 of 11 Old 09-25-2009, 07:27 PM
Terrible2
older cars like your model need them changed every 3k, newer cars dont really need to follow that rule. I have an 05, I change every 3-4k whenever its convenient. Of course if you off road more you should change your oil more often.
Terrible2 is offline
post #9 of 11 Old 09-25-2009, 07:48 PM
PT's93
Most manufacturers recommend a mileage, or 6 months, whichever comes first.
If you change it in October or November, and in April or May, you're not changing it when you get popsicles if you remove your gloves.
1998 ZJ Limited 5.2 ** 1996 Explorer Limited 5.0 ** 1882 Honda GL500 ** 1993 XJ Sport (R.I.P.)
PT's93 is offline
post #10 of 11 Old 09-25-2009, 08:09 PM
sandman
when your driving any vehicle a very small ammount oil change intervals are no longer determined by mileage but time, like i said before change your oil every 3-4 months. i change my oil every 4 months and usually only have 1.5-2k on the clock since my last oil change.
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 11 Old 09-25-2009, 10:18 PM
wickerham
I drive less than 5000 a year, 3000 something last year.
They say 3000 miles or every 3 months for oil change.
I thought that was a little much so my scheduled changes are as follows:
#1 in December (fresh oil for winter + not too cold outside while changing)
#2 in April (fresh oil for the spring/summer + again not cold outside)
#3 in August fresh oil for summer/fall (just hot outside, but not cold!)
Four times a year hasnt given me any problems as of yet on any vehicle I've owned.
wickerham is offline
Oil change question MJeep04 ZJ Grand Cherokee Forum 7 12-24-2009 02:49 PM
Oil Change Question! kabrewski ZJ Grand Cherokee Forum 16 09-27-2009 10:30 AM
Oil change question... IN2000WJ ZJ Grand Cherokee Forum 9 04-21-2008 11:29 AM
Thermostat Change Question 96country4x4 ZJ Grand Cherokee Forum 1 10-05-2004 02:41 PM
4.7HO Oil change question ATLDiver WJ Grand Cherokee Forum 22 11-11-2003 03:08 PM
