oil change and coolant change - JeepForum.com
post #1 of 8 Old 10-19-2007, 11:20 AM Thread Starter
thudson331
Hey guys,
once again i am needing some help. I am changing the oil and coolant on my 99 laredo. i have drained it of oil and changed the filter. the only prob now is i cant get the oil fill cap off Is there a certain nack to this cap and not like other cars that just twist off this brings me to my next question...how do you get the coolant to drain. i opened the bottle fill cap and then turned the drain on at the bottom of the rad...NOTHING honestly i am stumped. Lastly, after this is done, how do i get rid of the 'PERFORM SERVICE' light from showing and beeping?
thanks,
Troy
thudson331 is offline
post #2 of 8 Old 10-19-2007, 11:51 AM
Eshindi
For the engine oil make sure that the engine is cool
Taken from my manual
DRAINING ENTIRE SYSTEM
Use this procedure if the entire cooling system is to
be drained, such as for engine removal.
(1) DO NOT remove radiator cap first. With engine
cold, raise vehicle on a hoist and locate radiator
draincock.
† 4.0L 6-cyl. Engine: Radiator draincock is located
on the right/lower side of radiator facing to rear of
vehicle.
† 4.7L V-8 Engines: Radiator draincock is located
on the left/lower side of radiator facing to rear of
vehicle.
(2) Attach one end of a hose to the draincock. Put
the other end into a clean container. Open draincock
and drain coolant from radiator. This will empty the
coolant reserve/overflow tank. The coolant does not
have to be removed from the tank unless the system
is being refilled with a fresh mixture. When tank is
empty, remove radiator cap and continue draining
cooling system.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #3 of 8 Old 10-19-2007, 11:53 AM Thread Starter
thudson331
thanks eshindi but i have done all of that and still nothing. the oil cap is making a clicking noise like it is child proofed or something and the coolant just wont budge.
post #4 of 8 Old 10-19-2007, 11:53 AM
Redbob
Assuming there's nothing wrong with your grip <grin> I can't say why you couldn't get the oil fill cap off - it's an ordinary RH thread, so turning it CCW (you ARE turning it CCW aren't you?) is what removes it.
Radiator drain should be simple too. But you've got to also remove the radiator pressure cap so the fluid can come out.
Redbob is offline
post #5 of 8 Old 10-19-2007, 12:09 PM
impuresoul2k3
just clicking sounds like maybe the top plastic part of the cap broke off of the metal part and just the plastic piece is spinning
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #6 of 8 Old 10-19-2007, 12:30 PM
Johnny World
Johnny World's Avatar
Have you tried pushing down on the oil cap and nudging it a little left and right? maybe nudging will get the cap to fall into slot so it can be loosened.
'02 WJ, Laredo Special Edition, 4.0L I6
Johnny World is offline
post #7 of 8 Old 10-19-2007, 02:31 PM
CMARJEEP
CMARJEEP's Avatar
this just happened to me when i changed my oil. the teeth inside the oil cap that make it so you cant over tighten it strip off and therefore makes it impossible to get it off (the right way that is). so the oil fill cap is actually 2 pieces. take a big flathead screwdriver and pry off the top piece... yes pry it off. it come off quite easily by just going around and prying the edges. once you get that off you will see the metal part that is actually the part that screws in. take a pair of vice grips and just turn it counterclockwise. this is the only way i have found to get the fill cap off until you get a new one. good luck.
CMARJEEP is offline
post #8 of 8 Old 10-19-2007, 04:51 PM
PA 5.9
For the coolant, it may be plugged a little. Get some wire and push it up through the drain **** and that might break up the clog. Good luck.
PA 5.9 is offline
Coolant change xmonger ZJ Grand Cherokee Forum 1 06-15-2009 08:23 AM
Coolant change with front skid? xmonger ZJ Grand Cherokee Forum 1 06-15-2009 02:27 AM
Coolant Change/Flush brsox88 ZJ Grand Cherokee Forum 19 12-02-2007 09:12 AM
How do I change a coolant sensor rjbasile ZJ Grand Cherokee Forum 6 05-20-2007 03:10 PM
Need to change out my sister 2004 passenger side tailight , steps to change it? chaznad ZJ Grand Cherokee Forum 3 09-27-2005 05:51 PM
