Oil being sucked into air filter from Valve cover - JeepForum.com
post #1 of 6 Old 01-10-2009, 03:00 PM Thread Starter
ZJcrawler45
For some reason oil is being sucked through the valve cover hose to the airfilter. The only reason i can think of why this would happen is if i'm not getting a good amount of air and therefore my engine is creating a vacuum and sucking the oil up into the air filter. If i explained that right? Do you think that's my problem or is it something else?
Captain Nate
ZJcrawler45 is offline
post #2 of 6 Old 01-10-2009, 03:16 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The blow-by (aka PCV) orafice on the valve cover is bad.
Common issue.
It's the rubber grommet lookin thing on the valve cover connected to the hose that goes to the air cleaner.
Cheap easy fix.
Later model valve covers have a shield inside them that helps the blow by oil stay inside.
Cheap fix is to just replace the rubber orafice (and expect to replace it every 20-30k miles).
More expensive fix is to replace the valve cover with a newer style.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 6 Old 01-10-2009, 03:57 PM Thread Starter
ZJcrawler45
you mean the piece that actually twists into place on the valve cover? All i'm finding is the replacement hose. i thought it was just a straight through hose.
Captain Nate
post #4 of 6 Old 01-10-2009, 04:05 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Yes, the rubber piece/grommet that twists into the valve cover.
It's the modern version of a PCV valve.
It has a little rubber check valve built into it, under where the hose connects.
Go to your local Jeep dealer parts dept., and mention '4 litre blow-by', and they will (or at least should) know exactly what you are talking about.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 6 Old 01-10-2009, 06:53 PM Thread Starter
ZJcrawler45
ok thanks!
Captain Nate
post #6 of 6 Old 01-10-2009, 07:08 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You're welcome.
Even though you're a buckeye, you deserve answers cause yer a Jeeper
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
that little evap valve thing next to the air filter... proeliumfessus ZJ Grand Cherokee Forum 1 02-11-2010 07:41 AM
Valve Cover Gasket Mjov23 ZJ Grand Cherokee Forum 10 04-14-2009 10:14 PM
What else should I do with the valve cover off? the88thpianoman ZJ Grand Cherokee Forum 6 02-12-2009 11:58 AM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
