oil... - JeepForum.com
post #1 of 5 Old 07-11-2002, 10:31 PM Thread Starter
jeepdude93
oil...
what brand and weight of oil should i use for a 93 6 cylinder grand cherokee?
Chris
-93 Gr. Cherokee laredo, slyvania silverstar headlights, Pioneer Premier dehmp740 head unit, pioneer as1767 speakers in the rear, custom mesh wire grill inserts
jeepdude93 is offline
post #2 of 5 Old 07-12-2002, 07:12 PM
TheTick
2010 JK Wrangler
SAE10W30
Of course your vehicle may be new enough to get away with a synthetic oil. Synthetic can sometimes protect better, but synthetic oils are very thin. I had an 87 Wrangler that I used synthetic oil in and I found all kinds of new oil leeks with it
After some new seals, I never went lower than 10W40 again.
'07 JK "TheTick"
TheTick is offline
post #3 of 5 Old 07-15-2002, 11:11 PM
94gclimited
I use Valvoline Max Life 20w50 in my 318 with 119k miles. If you have higher mileage run either Maxlife or Castrol GTX high mileage oil. These new "high mileage" oils seem to be becoming popular but Valvoline was first so i tend to think theirs might be best at least for now.
Jason
94gclimited is offline
post #4 of 5 Old 07-17-2002, 01:27 PM
JeepGuyRyan
I'm very happy and satisfied with the Valvoline 10W30. As previously stated by Tick, if your vehicle has low millage you might consider synthetic, but I would probably shy away from useing that on something that has over say 85,000 miles.
Make sure you use a good oil filter as well which isn't always going to be the most expensive brand out there.
Ryan
-=Ryan=-
JeepGuyRyan is offline
post #5 of 5 Old 07-17-2002, 11:21 PM
SBrudzinsky
SBrudzinsky's Avatar
I would recommend
ROYAL PURPLE "SAE" GRADES MULTI-VIS MOTOR OIL
http://www.royalpurple.com
http://www.synerlec.com/
SBrudzinsky is offline
