oil for 5,2 ? - JeepForum.com
post #1 of 7 Old 08-20-2013, 12:39 PM Thread Starter
loodi
oil for 5,2 ?
so my v8 is close to hit the 250k km mark.
gonna need some oil.
gonna change all fluids actually but one is just confusing me... engine oil.
till now, PO used some castrol magnatec 5w40.
imho, not dense enough for an engine so used.
on top of that, 1kg of castrol magnatec is about....mumble...fast eur-dollar conversions....damn math.......damn brain....: about 20$.
now, for a bit more, for like.... 30$ i can get 5kg of some Wurth 10w50. i really doubt there is more than just the slightest quality difference. not even worth mentioning.
am i right?
should i stick to some more expensive fluids? is an engine as old and used as mine really worth it? could it feel any difference if i spend my money on a way more expensive oil?
loodi is offline
post #2 of 7 Old 08-20-2013, 01:03 PM
PolkaPower
am i right?
Is it a synthetic oil that has been used in the past? If it is I would continue to use synthetic. It lasts longer and is more heat resistant than dino. It also has less ash content. You can go longer between oil changes with a good synthetic as well.
I use what ever high mileage blend is on sale and change the oil more frequently until I fix my oil pan leak. Then I will switch to synthetic.
I had 10w 30 in it but during winter it gets to thick and I hear a knock at start up. I switched to 0w 40 and that helped a lot. It's super thin at start up and circulates better but is thicker at operating temperature.
PolkaPower is offline
post #3 of 7 Old 08-20-2013, 03:19 PM
Scopez
1994 ZJ
I use Castrol 10w-30 full synthetic. In both my 5.2L ZJ and my 5.9L Ram. No issues in either. 5.9L is around 250k miles.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #4 of 7 Old 08-20-2013, 03:35 PM
zj97ltd
Castrol GTX 10W30. It's pretty much the only thing that goes in any of my family's rides. But honestly I'd say having a good change interval is more important.
zj97ltd is offline
post #5 of 7 Old 08-20-2013, 03:45 PM
newfieZJ
Castrol 0W-30 only here . One of few 'true' synthetic oils , not a misadvertised blend . BMW uses it stock from the factory . Your engine will love you , your wallet , that is another story
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #6 of 7 Old 08-20-2013, 10:37 PM
kodenz
I read somewhere once that castrol's quality and detergents blow every other oil out of the water. I've stuck to it since then, because I believe everything I read on the internetz!
But seriously castrol all the way
5.2L 1997 ZJ limited Up-Country+2in BB
kodenz is offline
post #7 of 7 Old 08-21-2013, 03:39 AM Thread Starter
loodi
but money-wise: is it better to go for castrol every like 10k km or a cheaper wurth every 5k because its cheap?
(and after all, lets not forget what Wurth actually does. its ALL high quality stuff. i doubt their oil sucks)
loodi is offline
