Oh no, not another lift thread! (Very simple) - JeepForum.com
post #1 of 9 Old 09-27-2005, 12:58 PM Thread Starter
mr_user
Hey all,
I've been working on a transaction with a fellow JF'er for a 3" Skyjacker kit with 4 springs, shocks, front and rear trackbars, and all lower control arms. I need the shocks anyways so I might as well kill two birds with one stone. Assuming that I run my 2" spacers on top of the lift, would I need to run new brake lines as well? Would I be better off getting some 1" spacers?
Thanks
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #2 of 9 Old 09-27-2005, 01:30 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
You will definately want some longer brake lines.
I have the RE ones that are made by Russle. I ordered them from Kolak when I purchased all my random parts for the lift.
I believe you can same some cash and get the YJ brakelines. They are longer and will bolt right in
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #3 of 9 Old 09-27-2005, 02:02 PM Thread Starter
mr_user
Thanks Tim!
Are the extended brake lines the only thing needed to run 5"? Is there a big difference in driveshaft angles, etc. when running 5" instead of 3 or 4"?
What is the general concencus of the Skyjacker kit?
Matt
mr_user is offline
post #4 of 9 Old 09-27-2005, 02:14 PM
PumaZJ
skyjacker is crap. but depends on what you're going for. if you just want a lift to look cool yea it'll get the job done. as for the brake lines, I have the YJ lines, they're about 4 or 5" longer than stock. this could all be found by searching.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #5 of 9 Old 09-27-2005, 02:30 PM
SkyjacktZJ
SkyjacktZJ's Avatar
2015 WK
I'm running the 3" Skyjacker kit with a 2 1/8" BB from Kevin's. So far, so good. I've had the Skyjacker kit on for about 5 years and added the BB last fall.
No extended brake lines needed for me.
I've heard the same complaints about Skyjacker before, but personally I have not experienced any of it... so far.
2015 JGC Altitude Edition
Customer Preferred Package 23Z
Granite Crystal Metallic Clearcoat
SkyjacktZJ is offline
post #6 of 9 Old 09-27-2005, 02:34 PM
grandman97
grandman97's Avatar
matt- will u be able to run this guys 3'' shocks if u put the pucks under the lift and make it 5''??
grandman97 is offline
post #7 of 9 Old 09-27-2005, 02:51 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Originally Posted by mattfelner
Thanks Tim!
Matt
I would look into the shock issue that Mike just brought up.
If you are getting the longer / adjustable control arms then you should be fine. I would look into extended bumpstops. Elliot's solution (I like it BTW) is hockey pucks + RTV = $5 bumpstops. Less if you already have the RTV just sitting there. I will definately use this in the future.
Some rear extended swaybar links would be good too. Make your own with some all-thread and few couplers and some nuts!
You shouldn't have a problem with vibes and if you do, a TC drop kit is only $35 or something close.
OH YEAH... AND QUICK DISCO's But I have a feeling you have this issue covered
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #8 of 9 Old 09-27-2005, 02:53 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
My brake lines seemed huge, even with 5.5" they seem long. My only concern is the ABS lines. They are long enough, for now, but if I ever go longarm and 7+, I might be in trouble. I love the extra flex. Now to rear bumper w/tire carrier and sliders.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #9 of 9 Old 09-27-2005, 07:10 PM Thread Starter
mr_user
Thanks guys.
I didn't even think about the shock issue, but I figure I could temporarily run the 3" with 5" of lift, as for the past 5 months I've been running factory 60k mile old shocks with a BB.
I'll keep you all updated, for 300 bucks to get me up to 5" it seems to cheap to pass up.
Matt
mr_user is offline
A Simple Lift question 88chero ZJ Grand Cherokee Forum 5 02-22-2009 12:11 PM
Yeah, another lift thread 98ZJ_USMC ZJ Grand Cherokee Forum 13 04-11-2008 07:15 AM
Simple 2" lift, part two bluealtered ZJ Grand Cherokee Forum 9 01-31-2008 07:20 AM
simple 2" lift bluealtered ZJ Grand Cherokee Forum 2 01-28-2008 07:23 AM
