Odd idling? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Odd idling?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 02-24-2012, 09:14 AM   #1
sevenscrew
Odd idling?
if im sitting in park idling my jeep randomly shakes . its not that noticeable but enough to make the broken stuff inside my cat rattle randomly... recent new stuff.
idler pulley water pump tensioner(pulley) ps pump original pulley. plugs wires cap rotor.
my ps still has a little squealing but i was told itll fix itself over time. my belt has a little dry rot i need to replace but its not noisy yet.
Anyone know whats up? does with heat off.
1997 Limited 5.2L 3 link front. np231 swap
in the works: lp30 + 8.8 build to 4.88s + wj swap
sevenscrew is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 09:51 AM   #2
PolkaPower
How do the motor mount look? Mine has a bad plenum gasket and it idles rough sometimes. It's fine after I put octane booster in.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 10:11 AM   #3
sevenscrew
how do i tell if plenum gasket is. bad.
what do i check for on bushings
Unread 02-24-2012, 02:33 PM   #4
hdrocknroll
Take a good look at motor mounts.
Mine was doing same.
old on right
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 02:43 PM   #5
PolkaPower
To check the plenum you have to remove your throttle body and look way back towards the back with a bright flashlight. If you see any signs of motor oil then it's bad.
Unread 02-24-2012, 03:49 PM   #6
JasonStebbins
Check your motor mounts, clean out the IAC, replace the belt, buy a new converter. Start with the IAC and belt first, cheapest.
JasonStebbins is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 03:53 PM   #7
sevenscrew
iac is cleaned already. will replace the belt and cat asap
Unread 02-24-2012, 04:22 PM   #8
Tre3
did you clean the throttle body? mine did the same and i just cleaned the throttle body not the iac and it did in once the day after but once everything got goin it hasn't done it, that was about 2 weeks ago
Tre3 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 04:32 PM   #9
SAR-Swimmer
Did it do this before changing plugs, wires, cap, and rotor ? If not, recheck plugs are tight, wires on snug, cap and rotor on properly, and wires routed right. I vaguely remember a thread regarding a TSB about plug wire routing about a month ago, ( I've got an excellent memory, it's just real short).
SAR-Swimmer is online now   Reply With Quote Quick reply to this message
Unread 02-24-2012, 05:33 PM   #10
sevenscrew
ill look for how to wire correctly tbh i forgot if it did it before or not.
Unread 02-25-2012, 01:48 AM   #11
hdrocknroll
There was a thread just the other day talking about plug wire routing, it had a TSB in it for the 5.2.
It had picture and instructions for rerouting. I guess it can cause all kinds of happy Jack crap.
If the wires cross each other they must cross at 90 to one another, not parallel
[/QUOTE]
Unread 02-25-2012, 07:16 AM   #12
sevenscrew
okaythanks ill look
Unread 02-25-2012, 07:39 AM   #13
hdrocknroll
TSB
Ignition System Cross Fire/Secondary Ignition Wire Induction
(Complete Version )
[/QUOTE]
Unread 02-25-2012, 08:03 AM   #14
sevenscrew
idont have much of that plastic tubing so when i get some ill do this
Unread 02-25-2012, 08:14 AM   #15
hdrocknroll
Don't get me wrong here, I'm not saying this is your problem.
I'm just passing along information that might be, or might not be a solution.
[/QUOTE]
