Obdii Codes 12 And 55...need Help - JeepForum.com
post #1 of 4 Old 05-22-2003, 08:30 AM Thread Starter
CATMAN2
CAN ANYONE HELP WITH THIS.I DID THE IGNITION THING THE OTHER DAY AND CODES 12 AND 55 SHOWED UP.THIS IS WHAT I FOUND FOR CODE 12 (P0012 A Camshaft Position - Timing Over-Retarded (Bank 1 ). I DID NOT FIND ANY INFO FOR CODE 55.ALSO CAN I RESET WHEN PROBLEM IS FIXED OR DOES IT JUST GOES AWAY.I HAVE 1996 GC JEEP W/O 4WD
CATMAN2 is offline
post #2 of 4 Old 05-22-2003, 09:08 AM
lambar
I did find code 55 on the NAGCA website
55 Completion of fault code display on Check Engine lamp. . Sorry, but I can't help you on this. I'm new to this stuff.
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #3 of 4 Old 05-22-2003, 12:12 PM
Black96ZJ
code 12 is:
Direct battery input to PCM was disconnected within the last 50 Key-on cycles.
Nothing to be concerned about.
- Daniel
Black96ZJ is offline
post #4 of 4 Old 05-23-2003, 01:20 AM Thread Starter
CATMAN2
THANKS FOR THE REPLY GUYS, I GUESS I HAVE NOTHING TO WORRY ABOUT.
CATMAN2 is offline
AW4 Swap into an OBDII ZJ anticrombie ZJ Grand Cherokee Forum 27 09-01-2013 05:08 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 02:17 AM
OBDII Trouble Codes blakely03 ZJ Grand Cherokee Forum 4 03-15-2006 07:43 AM
1994 - OBD1 or OBDII ?? surfinmud ZJ Grand Cherokee Forum 2 10-24-2003 08:12 PM
