OBDII code P1763 - JeepForum.com
post #1 of 11 Old 09-27-2007, 11:16 AM Thread Starter
5.9forLife
OBDII code P1763
I drive a 5.9 and just had the check engine light come on so i plugged in and found the code it was throwing (P1763). Apparently it is that the Governor Pressure Sensor Voltage is too high. Has anyone ever had an issue with this? if so what can i do to fix it?
5.9forLife is offline
post #2 of 11 Old 09-27-2007, 11:23 AM
doug1810
Had this problem on a 47re cummins replaced sensor good to go
Try to pull and clean first maybe save some $$$$
doug1810 is offline
post #3 of 11 Old 09-28-2007, 07:35 AM
kentman
kentman's Avatar
2006 XK Commander
I highly recommend resetting the code. I get this code when it is really rainy wet and I plow into a puddle such that the undercarriage gets really wet. When I let it dry and reset the code, it does not come back. I have not seen this code for at least a year since the last time.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #4 of 11 Old 09-28-2007, 08:55 AM
ddevitto
p1763
had the same problem. changed the governor pressure switch and solenoid. i did it in a day. found all the info needed to do it under the faq area of this web site. not that hard to do, total cost was about $165.00 including parts and new oil.
ddevitto is offline
post #5 of 11 Old 09-28-2007, 09:31 AM Thread Starter
5.9forLife
Thanks guys i really appreciate all your help. I was worried it may be something bigger than that.
post #6 of 11 Old 09-28-2007, 09:55 AM
Creek-Chub
This might be a dumb question, but where is the FAQ section for the site located at?
Creek-Chub is offline
post #7 of 11 Old 09-28-2007, 11:17 AM Thread Starter
5.9forLife
Did any of you have trouble with the transmission when this code was being thrown? It seems like the car is starting off in second gear and cant get good power.
post #8 of 11 Old 09-29-2007, 02:43 AM
kentman
kentman's Avatar
2006 XK Commander
It will go into limp mode. I think that something like three cycles of the ignition will take it out of limp mode. Get out of limp mode and reset the code, and I bet that you will be good to go. If the code keeps coming back, then you can resort to swapping the solenoid. I have done the solenoid swap dance once in the past, but I believe that it may not be required.
kentman is offline
post #9 of 11 Old 08-06-2011, 10:13 PM
IL_WJ04
Just got the P1763 code this evening on my 04 WJ drove about 20 miles home with it stuck in 3rd gear. Tomorrow I will try and get it out of limp home mode then clear the code and see if it comes back. Anyone have a link to the forum where someone replaced this sensor?
Thanks,
-Pat
IL_WJ04 is offline
post #10 of 11 Old 08-07-2011, 08:23 AM
technophat
I was recently stuck in "limp mode" in my 42re. I was throwing both the p1763 and a p1762 codes. I replaced the Transmission Governor Pressure Solenoid and the Transmission Pressure Sensor, and the problem was solved. It did take a few days for the jeep to return to normal operation though, even with resetting the codes and disconnecting the battery. Couldn't tell you why. I bought the parts through:
http://www.transmissionpartsusa.com/...rs_s/10538.htm
And I followed this YouTube vid:
http://youtu.be/TWXaoC3Qi7g
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #11 of 11 Old 08-07-2011, 11:05 AM
98mopar
I just did it to my 5.9 a few weeks ago. Same code, had no 1st gear. Got the solenoid, and the sensor and the gasket for $103 from a place called transtar industries. Good to go. I reused the old trans. fluid, shifts strong, no problems!
--- 1998 ZJ 5.9 Limited - 4" lift, 31 x 10.50 15, Jet chip, Kenwood Excelon everything, current DD
--- 1996 ZJ Laredo - Parts parts and more parts
--- 1993 ZJ Laredo - 4.0 Bone stock for now (New to me)
98mopar is offline
Help! OBDII code P0351...x2 rooster51 ZJ Grand Cherokee Forum 82 11-17-2016 07:00 PM
help p1763 fmac ZJ Grand Cherokee Forum 3 02-27-2010 09:45 PM
need help 97 ZJ CEL (P1763) indredsnake99 ZJ Grand Cherokee Forum 1 10-07-2008 08:50 PM
P1763 code notchback ZJ Grand Cherokee Forum 9 10-26-2005 05:40 PM
OBDII CODE 1757 Governor Pressure zoom248 ZJ Grand Cherokee Forum 0 05-20-2004 08:33 PM
