OBDI check engine code 35? help please - JeepForum.com
post #1 of 4 Old 12-20-2012, 06:34 PM Thread Starter
M0DALsoul
I'm not sure if i read this properly but i posted a video
http://www.youtube.com/watch?v=YblYN...ature=youtu.be
M0DALsoul is offline
post #2 of 4 Old 12-20-2012, 06:57 PM
KoreaZJ
1994 ZJ
1-2 / Battery disconnected
4-1 / Generator Field Not Switching Properly
5-5 / End of codes
KoreaZJ is offline
post #3 of 4 Old 12-21-2012, 10:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Bad computer.
ratmonkey is offline
post #4 of 4 Old 12-21-2012, 11:17 AM
jnowak
Wouldn't jump to bad pcm. Mine had that code along with battery gauge showing little voltage. I could hit the alternator with a long pipe and it would start working again. Until i replaced alternator. Granted the longer I waited the more appropriate amount of brute force was needed to make it start charging again.
jnowak is offline
check engine , check engine light , cooling fan , ecu , idle issue
