OBD1 and OBD2 - JeepForum.com
post #1 of 31 Old 11-01-2005, 05:02 PM Thread Starter
FDSJr
OBD1 and OBD2
I have a 94 Grand Cherokee Limited (5.2 L V8), a 96 Cherokee Classic (4.0 L 6), and a 98 Grand Cherokee 5.9 Limited (5.9 L V8). I am getting a little tired of paying dealers to read fault codes and then charge me large amounts of money to fix the problem. I am considering getting my own OBD code reader. I am guessing that my 94 is OBD1 and the 96 and 98 are OBD2.
Does anyone know if an OBD2 code reader will also read OBD1 codes (with the right adapter cable for the connector)?
FDSJr is offline
post #2 of 31 Old 11-01-2005, 05:25 PM
JCDubya
2009 WK
OT: I wonder if OBDII ZJ's can be converted to OBDI. I did that in my Integra...
JCDubya is offline
post #3 of 31 Old 11-01-2005, 05:53 PM
-Joe-
-Joe-'s Avatar
Why cant you just use the check engine and key on/off 3x cycle to grab the codes?
I recall trying this in a friends 2001 and it worked as well. (I know it works on 94-95s as well)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 31 Old 11-01-2005, 06:57 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I know you can use the 3 cycles thing up until 04 on GC. Next time I'm at a dealer, I'll try it with a WK.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #5 of 31 Old 11-01-2005, 07:28 PM
greasefingers
greasefingers's Avatar
1994 ZJ
There is nothing that I know of that can support both OBDI & OBDII. If there is then it will cost several hundred. You can get nice one that connect to your PC from $ 100 to $ 300. IMO it would not be worth it to buy an OBDI scanner for our jeep.
I tried the key-cycle thing on a 1999 Cherokee. It did not work. But it works on mine
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 31 Old 11-01-2005, 07:29 PM
Woody
Woody's Avatar
1985
Maybe you had a fluke, it worked on my 99 and the neighbors 04.
Woody
Woody is offline
post #7 of 31 Old 11-01-2005, 07:32 PM
greasefingers
1994 ZJ
This was a 99 cherokee and not a grand.
Cheers Steve
post #8 of 31 Old 11-01-2005, 07:34 PM
Woody
Woody's Avatar
1985
Most curious, makes me want to put on the Sherlock Holmes hat.
Woody
Woody is offline
post #9 of 31 Old 11-01-2005, 07:40 PM
greasefingers
1994 ZJ
1996 & 1999 were very strange years for jeeps.
Cheers Steve
post #10 of 31 Old 11-01-2005, 07:42 PM
Woody
Woody's Avatar
1985
I think they hired rejects or prison innmates those two years.
Woody
Woody is offline
post #11 of 31 Old 11-01-2005, 07:46 PM Thread Starter
FDSJr
I'll give the key on-off cycling thing a try. I had a 96 Dodge Neon awhile back that that trick worked on. It is a lot cheaper than a code reader.
FDSJr is offline
post #12 of 31 Old 11-01-2005, 07:48 PM
Woody
Woody's Avatar
1985
We try to save folks money, sometimes we can, and sometimes we are the bearer of bad news. I'm glad we can save you some though.
Woody
Woody is offline
post #13 of 31 Old 11-01-2005, 07:50 PM
-Joe-
-Joe-'s Avatar
Im also pretty sure the 99 limited my friend bought after she totaled the 01 it worked on as well.
- Joe -
-Joe- is offline
post #14 of 31 Old 11-01-2005, 10:02 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
My 94 OBDI works with the key cycles.
I tried the key cycle in my Dad's 97 XJ, his displayed the codes in both ways... the 'P' xxxxx codes (digital odometer) and the blinking CE light. (97+ XJ's had the digital odometer) this where the P codes are displayed on the WJ too. Not sure if this helps or just adds to the confusion!
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #15 of 31 Old 06-04-2013, 09:57 PM
dnuccio
Originally Posted by obd2 View Post
obd2 diagnostic tool supplier,honest obd2 http://www.hobd2.com/
<a href="http://www.hobd2.com/">obd2</a> diagnostic tool supplier,honest obd2
sales@HOBD2.com
sales@HOBD2.com
sales@HOBD2.com
sales@HOBD2.com
www.hobd2.com diagnostic tool supplier,honest obd2
you bumped an 8 year old thread just to spam it?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
OBD1 key on-key off technique? spikeystrip ZJ Grand Cherokee Forum 2 07-14-2009 01:29 PM
95 GC 5.2 can you test OBD1 spikeystrip ZJ Grand Cherokee Forum 1 07-09-2009 09:57 PM
Tuning Options for OBD1 V8 RebelW26GT ZJ Grand Cherokee Forum 6 09-12-2007 08:02 AM
Obd2 CowboysWJ ZJ Grand Cherokee Forum 4 12-28-2006 07:08 PM
1994 - OBD1 or OBDII ?? surfinmud ZJ Grand Cherokee Forum 2 10-24-2003 08:12 PM
