OBD II codes PO320 and PO455 - JeepForum.com
post #1 of 12 Old 07-21-2009, 09:59 AM Thread Starter
02grand
Can someone let me know what these codes means and if there is a common way to fix. The 455 has been on for a while but the 320 came on after we went wheeling so not sure. Thanks
02grand is offline
post #2 of 12 Old 07-21-2009, 10:04 AM
timatoe
timatoe's Avatar
P0320 = Ignition/Distributor Engine Speed Input Circuit Malfunction
P0455 = Evaporative Emission Control System Leak Detected (gross leak)
Not sure about the 320, but my Durango kicked the 455 code before with a bad fuel cap.
timatoe is offline
post #3 of 12 Old 07-21-2009, 10:28 AM
rm2001wj
rm2001wj's Avatar
P0320 = No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC)
= A CKP signal has not been detected at the PCM
That means that the crankshaft position sensor needs to be replaced. There's an outside chance that something happened to the wiring harness connector at the sensor while you were wheeling, so check that first.
rm2001wj is offline
post #4 of 12 Old 07-22-2009, 01:15 PM Thread Starter
02grand
The cap was just relaced aboutthre mnths ago becaus eit failed emissions. Could maybe a air line to tank got cracked? Thanks for your help. Ill check that harness and sensor this weekend.
02grand is offline
post #5 of 12 Old 07-22-2009, 01:31 PM Thread Starter
02grand
Hey guys another question quick. The aprt number is saying it fits from 97 to 04. Is that true. I thought maybe i try one from junkyard to make sure it is problem before i buy new one and it might be broken wire. Thanks
02grand is offline
post #6 of 12 Old 07-22-2009, 01:45 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Is this on a WJ? EVAP leaks are common. Its usually the gas cap, leak detection pump, or one of the vacuum lines split.
WiCkeDuDe is offline
post #7 of 12 Old 07-22-2009, 01:54 PM Thread Starter
02grand
yes wj. I thought maybe one of the lines were split so ill check those and let you guys know what happens. Thanks
02grand is offline
post #8 of 12 Old 09-30-2009, 01:45 PM
Redrider39
2003 KJ Liberty
The P0455 is a vacuum leak for sure. I've got 2 liberties and have replaced every vacuum line in both from front to back. Jam full of cracked hoses. (Canister hoses that is.) I have just had my first encounter with the P0320 code. I have a crankshaft position sensor ordered and should have it in by tommorow. Will coment afterwards.
Redrider39 is offline
post #9 of 12 Old 09-30-2009, 01:46 PM Thread Starter
02grand
Did replacing hoses work? Where did you get hoses from. Thanks
02grand is offline
post #10 of 12 Old 09-30-2009, 07:05 PM
Redrider39
2003 KJ Liberty
Yes, replacing the hoses worked great. Sorry I didn't complete my statement before. Just get some 3/8 and 5/16 stock hose from your auto supply. I actually used transmission hose. It is reinforced and a lot thicker. Never saw the P0455 code again.
post #11 of 12 Old 10-01-2009, 11:54 AM
Redrider39
2003 KJ Liberty
Just to let y'all know, I repaired the OBDII code: P0320 problem with a crankshaft position sensor. The bluejeep is back on the road.
post #12 of 12 Old 10-01-2009, 12:44 PM
Redrider39
2003 KJ Liberty
I'm new to the forum so don't laugh toooooooo hard but what is the difference in a KJ and KK Liberty?? I know, ha ha ha.
2002 Wj Po455 almostfinished ZJ Grand Cherokee Forum 4 12-10-2009 12:00 PM
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 02:59 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 03:17 AM
TCM P0750...codes and more codes and the one speed tranny Mattt0305 WK Grand Cherokee & XK Commander Forum 3 11-01-2008 10:50 PM
6 Codes... New to codes and Tranny issues jakewalczak ZJ Grand Cherokee Forum 6 02-06-2008 08:32 PM
