OBD-II code P1494/leak detection pump defective?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > OBD-II code P1494/leak detection pump defective??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 04-28-2008, 04:09 PM   #1
belgian64
My check engine light came on, on my 199 Jeep Grand Cherokee Laredo 4x4(with the 4.0 liter straight six), I had it checked at Autozone and an independent garage, they both came up with code number 1494 when they did the OBD-II check, which said "leak detection pump defective" (open or shorted circuit condition, or solenoid defective). What is it? Where is it located, and how do I fix it so I can pass inspection?? Someone on a forum wrote in they had the same code (P1494) on a 99 Grand Cherokee, and it just needed a new gas cap...is that possible?? Please help....
belgian64 is offline   Reply With Quote
Unread 08-07-2008, 06:25 PM   #2
smg14
Hey man,
I just encountered the same problem on my GCL. Did you ever figure ut how to fix it and what caused the issue?
smg14 is offline   Reply With Quote
