O2 sensor shorted out PCM? - JeepForum.com
post #1 of 4 Old 01-15-2014, 01:54 PM Thread Starter
ConnorZJ413
I posted earlier on this issue but have broken a little ground. My driveshaft ripped my downstream o2 sensor wires out of the exhaust plug, which resulted in them dragging on the wet ground this morning. My asd relay is good and the o2 harness has suffered a little damage but not much. When I turn it on she crank and cranks with all lights working, dashboard/overhead, but none o my guages work at all, they all sit at 0. Could the wet ground shorted my PCM? Or worse?
ConnorZJ413 is offline
post #2 of 4 Old 01-15-2014, 04:01 PM
Gearhead31
deleted. Bad info
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #3 of 4 Old 01-15-2014, 10:04 PM
JS97ZJ
#20 fuse in the PDC (under the hood fuse box) is probably blown. Make sure the wires are separated before replacing it.
You can drive it without the downstream o2 but it will register a fault code and affect the gas mileage a little.
The downstream mainly monitors the health of the cat.
If the fuse blows again after the you've done the above, your PCM has probably gone bad.
JS97ZJ is offline
post #4 of 4 Old 01-16-2014, 11:09 AM Thread Starter
ConnorZJ413
Yes I checked all fuses and relays. Great info though!!!
