O2 sensor? probably the 10,000th thread - JeepForum.com
post #1 of 14 Old 06-26-2007, 02:19 PM Thread Starter
Grazsrootz
hey guys im sure you get this alot, i have a bad 02 sensor in my 01 JGC limited and i have a check engine light on, i had it checked and it is the sensor after the cat. does this sensor really affect the engine much? what does it do to affect the engines performance, i havent really noticed anything different since when i bought it a month ago, i get about 12mpg around town and 19-20 on the highway. will replacing this sensor help my mpg and performance. also i have a problem with an idle which is not steady sometimes 500rpm sometimes 1100 rpm it tends to vary, could this sensor be causing this? now for the big question where i can i get this sensor for cheap and is it different than the one for the 4.0l. also is the one before the cat the same as after the cat?
thanks alot guys
Grazsrootz is offline
post #2 of 14 Old 06-26-2007, 03:10 PM
gomes512
1994 ZJ
DIdn't Chrylser have like a clearance or sale or something on o2 sensors recently?
gomes512 is offline
post #3 of 14 Old 06-26-2007, 08:13 PM Thread Starter
Grazsrootz
i dunno, where would i find that
post #4 of 14 Old 06-26-2007, 09:30 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
that was a couple months ago. i just paid normal price for all 4 of em.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 14 Old 06-26-2007, 09:35 PM
rm2001wj
rm2001wj's Avatar
In a WJ, a downstream (after the cat) O2 sensor is used to fine tune the mixture, besides measure cat efficiency. As long as the upstream sensor works properly, the downstream sensor has very little affect on performance or mpg. That sensor has nothing to do with your idle problem.
Getting a cheap O2 sensor is not a good idea. A Mopar sensor from the dealership pays off in the long run and you don't have to cut and solder any wires to connect it to the wiring harness. In the parts catalog, each of the four O2 sensors has a different part number. The sensors are probably identical, but the pigtails that connect the sensors to the wiring harness have different lengths.
Kolak (kolak@aol.com) has good prices on Mopar parts.
rm2001wj is offline
post #6 of 14 Old 06-27-2007, 04:50 AM
Kolak
Vendor
Kolak's Avatar
Thanks for the recommendation. Just to remind everyone, I offer JeepForum members a 25% discount off what you'd pay at the dealership for all genuine Mopar parts.
Kolak is online now
post #7 of 14 Old 07-08-2007, 09:12 PM
Chomot
Hi Kolak,
What would the two upstream mixture O2 sensors run me, including shipping to Houston for an 02 WJ Limited with the 4.7?
Chomot is offline
post #8 of 14 Old 07-08-2007, 09:49 PM
MotoX5874
for your idle problem, try cleaning your IAC.
Brian
// 5.2 // 4.5" iro // 33" baja claws
MotoX5874 is offline
post #9 of 14 Old 07-09-2007, 05:23 AM
Kolak
Vendor
Kolak's Avatar
Originally Posted by Chomot
Hi Kolak,
All four sensors should be replaced at the same time on the 4-sensor systems. The downstream sensors do their fair share in terms of influencing the mixture.
Send me a PM if you'd like a quote for the sensors.
Kolak is online now
post #10 of 14 Old 08-12-2009, 05:14 PM
JonM81
I have an 04 WJ I6 with the engine light on. MPGs are tankin and the WJ idles rough several times a day... Engine light comes on and off (I am in my car all day). Had autozone scan it and said its running rich or lean on one bank only. Possibilities: defective o2 sensor, ignition misfire-repair, fuel injector problem.
I am hoping its a sensor. Had the fuel pump replaced 5K miles ago, 133K on the WJ.. How do I tell if I have the 2 or 4 o2 sensor set up without getting under the car? Thanks for any help...
Jon
La Vernia, TX
2004 WJ Grand Cherokee Laredo
4.0L Straight Six w/ 140xxx Miles
K&N Drop In w/ Air Box Mod
JonM81 is offline
post #11 of 14 Old 08-12-2009, 06:04 PM
UrbanOffRoad124
Really, I never had an O2 sensor after my cat, just one before. I only have a total of 3 - O2 sensors. I have the 4.7HO and I know it has a different exhaust system from the factory. Other than my manifolds and the down tubes back to the O2 sensor is stock, the rest has changed. But I never removed a fourth O2 sensor when changing my exhaust and cat......
'02 WJ | 4.7HO | Limited | QDII | 3.5" Lift (BB+OME Springs) | JKS TB | JKS Quick Disco's | JKS BPE's | RC Nitro 9000's | Rusty's SS | K&N FIPK | 40 Series Delta | Cat-Delete |
Coming soon: 31" KM2's | 15x8 Cragar V-5's
#236 |
#232
"those who do, can't explain; those who don't, can't understand"
UrbanOffRoad124 is offline
post #12 of 14 Old 08-23-2009, 08:43 AM
Steve01WJ
2005 WK
So I have an 01 WJ and I dont have an 02 sensor anywhere near my cat...is that normal?
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #13 of 14 Old 08-23-2009, 09:21 AM
Kolak
Vendor
Kolak's Avatar
You definitely have four O2 sensors, or at least you're supposed to unless one is missing. There are two upstream and two downstream sensors, one before and one after each precat.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #14 of 14 Old 08-23-2009, 09:22 AM
Kolak
Vendor
Kolak's Avatar
All WJs with precats do not have an O2 sensor at the main converter. They're all located adjacent to the precats.
or
Kolak is online now
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 12:01 AM
O2 sensor thread count sean924 ZJ Grand Cherokee Forum 0 10-16-2009 05:14 PM
Screw/Thread size; Throttle Position Sensor jefkawst ZJ Grand Cherokee Forum 3 03-19-2009 12:22 AM
bad coolant sensor thread again crazynut52 ZJ Grand Cherokee Forum 1 01-03-2005 10:43 AM
1,000,000th Jeep Grand Cherokee Meerkat ZJ Grand Cherokee Forum 3 02-21-2004 10:10 AM
