O2 sensor plug - JeepForum.com
post #1 of 8 Old 08-01-2009, 07:23 PM Thread Starter
wickerham
O2 sensor plug
How in the world do you plug the O2 sensor in into a '93 ZJ? I'm doing my exhaust in a few days and was underneath today after an oil change measuring and what not. Anyway, I bought a new sensor (mines got 86k...figured "why not?") So I trace the wire from the sensor in the pipe up until it disappears above the tranny. Don;t tell me I gotta drop the tranny just to plug in a sensor?!?! looks like there's a panel up there. Think you can remove the center console and plug in from above?
wickerham is offline
post #2 of 8 Old 08-01-2009, 07:39 PM
lateralus3
1994 ZJ
its been a while since ive done one but on my old dodge shadow i had to cut the wires and splice it in. i dont know if thats how it is on a jeep
lateralus3 is offline
post #3 of 8 Old 08-01-2009, 07:55 PM
vansskaterfreek
it should be plug and play..... all the jeeps ive seen they were...
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #4 of 8 Old 08-01-2009, 08:13 PM
elmer_fud
Remove the heat shield above the exhaust pipe and slide it back. Then get a coat hanger (I actually used thicker wire) and bend it into a U shape at the end to hold the top of the plug. remove the old sensor and plug the new one in BEFORE threading it into the exhaust pipe.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #5 of 8 Old 08-02-2009, 06:26 PM Thread Starter
wickerham
Removing the heat WOULD work, just gonna be a squeeze. Thanks, man. Also, very good call on plugging in BEFORE threading in new. Nice!
post #6 of 8 Old 08-02-2009, 06:31 PM
elmer_fud
yeah, I have replaced my O2 sensor twice, last time was about 3 days ago. In my jeep I couldn't reach the bottom of the plug with the heat shield there but I may have bigger arms/hands or my exhaust is in a slightly differn't place.
Brian
post #7 of 8 Old 08-02-2009, 06:52 PM Thread Starter
wickerham
3 times?!?! must explain.
Oh, and idk? just can't even see where the wire goes after the tranny.
also, my new bosch O2 is waaaaay thicker than the OEM mopar one.
post #8 of 8 Old 08-02-2009, 06:58 PM
elmer_fud
only twice, first time was 2-3 years ago. The check engine light came on for the O2 sensor. The second time was 3 days ago because I have been getting worse mileage than I should be (I should be at 17-20 and am at 15). I figured it is the O2 sensor causing the worse milage because my driving habits have not changed and the bosch sensors supposedly only last a year or 2 in our jeeps. I will find out in a few days, I replaced it with a mopar one.
the sensor you have will still fit even with the bigger diameter. It is what I used the first time I replaced my O2 sensor.
The wire runs up along the tranny about 6 inches to the connector. After the connector I think it runs up into the engine compartment somewhere.
Brian
crank position sensor plug location? brian86 ZJ Grand Cherokee Forum 6 11-17-2009 05:45 AM
HELP me pinpoint this sensor plug. vn712 ZJ Grand Cherokee Forum 9 10-16-2009 12:33 AM
Oil Pressure Sensor plug Gator6 ZJ Grand Cherokee Forum 3 02-29-2008 04:49 AM
Coolant Leak from Freeze plug/Sensor... kjopen ZJ Grand Cherokee Forum 10 09-08-2007 11:32 PM
D44A... rubber plug or screw-in plug on diff cover? BradMB2004 ZJ Grand Cherokee Forum 3 08-07-2006 07:33 AM
