O2 sens,mount where does it go ??? - JeepForum.com
post #1 of 3 Old 02-12-2012, 02:22 PM Thread Starter
hdrocknroll
The thing on the plug looks like its supposed to mount some where , but where?
The old one was hanging there not hooked to any thing
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 3 Old 02-12-2012, 03:30 PM
SAR-Swimmer
Your guess is as good as mine, but Haynes manual shows that sensor mounted to left side of engine, below exhaust manifold, (sensor it's self), and the wires going to a black plug that is for the oxygen sensor pick-up part of the PCM, (right rear engine compartment). IF haynes is right, and jeep didn't change wire colours, the "truck" side of the plug should have 4 wires coming out of it, 3 -18 guage, bk/lb,bk/tn,bk/or , and 1-14 guage or/db. If I were looking for that plug, I'd install the sensor end, and stretch the wire and plug out, and "swing" it in an arc, to give me an approximate location to start looking for the "truck side" plug, with a bias knowing the plug does come from PCM. The actual mounting location should be somewhere close to the end of the truck -side plug, at the distance of the sensor-side wires, probably with a little slack.
HTH
SAR-Swimmer is offline
post #3 of 3 Old 02-12-2012, 06:33 PM Thread Starter
hdrocknroll
I guess I wasn't very clear what I was talking about.
I was just replacing the O2 sensor. I know were it plug's into, I know where it goes, but the plastic part coming out the side of the plug. You see in pic is obviously supposed to be mounted someplace, but I don't know where, because old one wasn't mounted any place ,just hanging there.
Can't find it anywhere in the FSM
I secured it well, it to a bracket with zip ties for now.
If anyone knows where this is supposed to be mounted to (what it's supposed to be attached to) let me know.
Thanks
oxygen sensor
where to mount a cb? mattdillon09 ZJ Grand Cherokee Forum 23 10-25-2010 09:57 PM
Cb mount in wj SlowMo97 ZJ Grand Cherokee Forum 6 04-28-2009 10:35 PM
Trans mount replacement? '96-'98 mount into a '95 jailbird1818 ZJ Grand Cherokee Forum 5 04-17-2006 07:54 PM
CB mount in WJ askoop ZJ Grand Cherokee Forum 1 04-03-2005 10:52 PM
JGC Wont pass smog, Fuel Inj Service, OX sens and Cracked Exhaust Questions RomanVIII ZJ Grand Cherokee Forum 3 12-19-2004 10:25 AM
