O/D question - JeepForum.com
post #1 of 4 Old 10-13-2013, 07:40 PM Thread Starter
abraham743
O/D question
Rebuilt my 44re and works well in reverse 1 2 3 but makes no attempt to shift into O/D. Cruise works all fuses are good and no trouble codes. Any ideas? It's a 97 with a 5.2. When O/D off switch is pushed the light comes on and makes no difference in operation. I also bought this with the transmission not working. The O/D snap ring was broken and the pressure plate was smoked. So this may have been an issue before the build
abraham743 is offline
post #2 of 4 Old 10-14-2013, 07:47 AM
newfieZJ
You just rebuilt it ? or just installed it knowing the ring was broke etc ?
Either way , did you look into the accumulator spring being broken ?
newfieZJ is offline
post #3 of 4 Old 10-14-2013, 06:37 PM Thread Starter
abraham743
I rebuilt the trans accumulator springs are good. I bought it with the trans broke. This could have been a problem previously. I will figure it out later this week.
post #4 of 4 Old 10-15-2013, 05:32 AM
newfieZJ
Did you use all new solenoids in the trans , OD especially .
I got a 46RE with the same issue , couldn't get OD . I never did the OD solenoid before giving up and swapping in another . Same symptoms as yours .
newfieZJ is offline
