NV-249 engaging question - JeepForum.com
post #1 of 6 Old 03-21-2013, 07:24 PM Thread Starter
Maine1994ZJ
Hey, all!! I'm going to check out another ZJ for my wife to DD. It has a 4.0, 42RE, and NV-249. All with 229K miles.
My question is: If it's working properly, how long should it take the viscous coupling to engage the front axle when the rear axle spins?
I'm planning to run it through some snow to test it out and I was hoping to be armed with knowledge.
Any help is most definitely appreciated!!!!!
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #2 of 6 Old 03-21-2013, 08:05 PM
zarnold
If it's working correctly, the transfer will be instantaneous. Not sure how you will test that, but I'm sure somebody will know.
What you need to test is the VC itself. To do that first get to operating temp (e.g. drive for 20 minutes or so). Then in a parking lot drive in figure 8's. If you can idle through the 8's your probably OK; if it binds, jumps, hops or you have to give it gas to push it through the 8's your VC is probably already done, or on the way out.
86 CJ-7, 258 Engine, T-177, Dana 300, Dana 30, AMC 20
zarnold is offline
post #3 of 6 Old 03-21-2013, 08:37 PM Thread Starter
Maine1994ZJ
I was planning on backing it up a snowbank in 4HI to test it. That SHOULD work... In theory anyway
Will definitely do the figure 8s!! Thanks for the tip!!
post #4 of 6 Old 03-22-2013, 11:28 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
At that mileage if it hasn't been replaced its guaranteed to be bad. The 93-95 units don't last 100k and the 96-98 units are toast by 150k.
ratmonkey is offline
post #5 of 6 Old 03-23-2013, 07:10 PM
RTLee
Before you buy:
1: vehicle off, put in drive with emergency brake on.
2: jack up RF wheel.
3: use torque wrench set to 90lbs. Try to turn the wheel (using wrench). If wrench clicks, viscous coupler is bad.
4: walk away if wrench clicks.
Otherwise it's a TC swap or VC replacement. Each is pricey in their own way.
Good luck!!
Edit: source is Identifix and Chrysler service manual. This is how I found out my TC was bad.
RTLee is offline
post #6 of 6 Old 03-23-2013, 08:17 PM Thread Starter
Maine1994ZJ
Thanks guys. I went to see it. Long story, short The woman selling it was a TOTAL PSYCHO!!! I'm traumatized now...
20 minutes of my life I will NEVER get back
