NP249 T-case dying & want to swap to a NP242 or NP231 - JeepForum.com
post #1 of 16 Old 12-31-2008, 05:59 PM Thread Starter
IMin4Low
I have a '98 ZJ 5.9L & my NP249's had it. I've read the pros & cons of the 231 & 242 and have decided that although I off road quite a bit, I'd rather have the NP242 because I DD this a ton.
I take that the NP242 will just bolt in? ( I know, besides modifying the linkage & shift indicator) Which year/make donor would it be best to get it from?
Thanks for any & all help
IMin4Low is offline
post #2 of 16 Old 12-31-2008, 06:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you'll need to swap inputs as the v8 transmissions have longer input shafts on the tcases.
get it from a 97+ zj or xj.
ratmonkey is offline
post #3 of 16 Old 12-31-2008, 08:04 PM Thread Starter
IMin4Low
I thought I might have to swap inputs if the 242 came from a 4.0L, but wasn't there a NP242 option in the ZJ?
IMin4Low is offline
post #4 of 16 Old 12-31-2008, 08:08 PM
Jones
Consider the following...
Jones's Avatar
They did make them for ZJ's but I think only for the 4.0. I had a 231 in my old 93 4.0 ZJ but it crapped out.
Jones is offline
post #5 of 16 Old 12-31-2008, 08:14 PM
Reswob
You may have to swap input shafts, I didn't, but I needed a shorter rear DS from a ZJ that came with a 242. Try to get the case from a '97 or '98 ZJ.
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #6 of 16 Old 01-01-2009, 02:40 AM
UofOJeeper
Not true.
OP has a later ZJ. If you get the 242 from a later ZJ you will not have to swap input shafts. With the later ZJ, the 242s do not have the cone looking housing for the output shaft, instead they use a boot so I would also ask for the rear driveshaft from the vehicle the TC came out of!
1998 Laredo Special Edition V8
Toyo Open Country A/Ts - 245/70/R16
242 Swap
"A man who asks no questions, rarely has any answers"
UofOJeeper is offline
post #7 of 16 Old 01-01-2009, 05:58 PM Thread Starter
IMin4Low
Now you can understand my confussion. Thank you. I will look for a late model ZJ with the 242 then & not mess with splitting the case.
IMin4Low is offline
post #8 of 16 Old 01-01-2009, 06:35 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Wow...I could smell the misinformation and hearsay from a mile away - stinky
96 and up is what you're looking for (most likely). However, you really won't know what input you have until you have the old case on the ground. .840" exposed input shaft should be what you see on the 97.
Also - some 96-98s had the exposed tailshaft (booted driveshaft), some had the enclosed tailshaft (cone on the rear of the case). You need to make sure you get the same for yours in order to have the best chance of success.
In short: for a 96+, you need to look for a 96+ donor. Input shaft length should be .840", and match the output type (enclosed or exposed).
You can do an earlier case and swap inputs, but it's not a fun job...not a hard job, just not too much fun.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #9 of 16 Old 01-01-2009, 06:42 PM Thread Starter
IMin4Low
Thank you Thank you THANK YOU...... that's the 1st clear explaination I've seen. I'll drop it, measure & look for a match.
Thanks again FPKites, from the Western Slope!
IMin4Low is offline
post #10 of 16 Old 01-01-2009, 06:54 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Glad I could help with the info.
Wish I could help with the install, but GJ is a bit of a hike just for beer and pizza
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #11 of 16 Old 01-01-2009, 08:05 PM Thread Starter
IMin4Low
Not even for Canadian beer? Have got some good single malt scotch as well????? Am afraid we wouldn't get much done!!
I found a nice like for this swap as well:
http://jeephorizons.com/tech/tcase.html
So if I/anyone else can't find the "perfect" donor, here's how it's done.
IMin4Low is offline
post #12 of 16 Old 01-01-2009, 08:07 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Canadian beer would be even more of a deal breaker
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #13 of 16 Old 01-01-2009, 08:12 PM
Mickey_D
Yeah, but there ain't no 3.2 north of the border...
Most American beers need 5 to make up the alcohol content of 3 Canadian beers.
(unless of course he bought it here, in which case it isn't truly Canadian beer)
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #14 of 16 Old 01-01-2009, 08:24 PM Thread Starter
IMin4Low
Nope, is true blue Labatts bought proudly in Sault Ste Marie, Ontario just last week! M-M Good
IMin4Low is offline
post #15 of 16 Old 01-01-2009, 08:33 PM Thread Starter
IMin4Low
FYI......
http://www.nagca.com/grandtech/Jeep%...fer%20Case.pdf
This is a nice link showing lubes & capacities for axles & T-case. It also lists which vehicles came with what stock:
IMin4Low is offline
Transfer Case Swap Info NP249->NP231 & NP242 JrMechanic ZJ Grand Cherokee Forum 3371 Today 06:37 PM
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
How do I swap a NP249 for a NP242? FoxriderUTI ZJ Grand Cherokee Forum 1 10-01-2009 06:45 PM
NP249--Np242 swap capone518 ZJ Grand Cherokee Forum 3 05-21-2008 10:13 PM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
