NP249 Seal kit - JeepForum.com
post #1 of 5 Old 09-15-2012, 10:37 AM Thread Starter
jmp-n-run
NP249 Seal kit
I have a worn out VC and leaking transfer case, so digging in to fix it all!
I ordered the viscous coupler and seal kit for my NP 249 from crown automotive and was ready to start work this morning. I found the detailed description on this site for changing out the coupler - but what are the rest of the seals in this kit? Is there a write up about changing all of these out? Been surfing this site and all of the parts dealers looking for a part description of these kits all morning!
The kit had 6 different press in type seals, one gear tooth looking seal, and three small o-rings.
Thanks!
jmp-n-run is offline
post #2 of 5 Old 09-15-2012, 10:57 AM
JS97ZJ
There is a write on the np242 in the faq section but an other website has a pdf section (for educational purposes only) that has a partial FSM that will cover the disassemble and assembly of the 249......
http://www.jeep4x4center.com/knowled...ex.htm#service
JS97ZJ is offline
post #3 of 5 Old 09-15-2012, 12:16 PM Thread Starter
jmp-n-run
Great site! Didn't know that existed!!
So think I've got most of the seals figured out:
- 2 orings for the speedometer sensor and adapter
- 1 oring for the oil pump pickup
- the gear shaped washer is for the yoke seal
The seals that I can identify are:
- output shaft front seal
- front bearing retainer seal
- extension housing seal
- rear retainer seal
So this leaves two more seals. Any ideas? Could one of these possibly be for the output seal from the transmission?
post #4 of 5 Old 09-15-2012, 04:21 PM
JS97ZJ
You should fill in your Jeep's profile. 93-98 ZJ describes the particular model run, but many parts will differ from year to year. Get the TC id #'s off the back of TC so when ordering parts you'll get the right parts and everyone that wants to help has all your info.
JS97ZJ is offline
post #5 of 5 Old 09-15-2012, 08:00 PM Thread Starter
jmp-n-run
Done! Basically the 96 stock Grand Cherokee Limited with the V8 and all wheel drive. Got this cheap as a second vehicle - but definitely needed a little TLC. Already fixed the AC (new compressor) (top priority in South GA), trying to troubleshoot a battery drain, need to fix this TC (NP249), put on a 2" BB, new tires, and do something with the head liner that is sagging all over the place. This ol girl hit 200k miles when I was test driving her, but still strong.
Bad NP249 madslynge87 ZJ Grand Cherokee Forum 14 06-12-2012 05:11 PM
What causes a NP249 to die? ZJPunk98 ZJ Grand Cherokee Forum 35 10-28-2009 05:41 PM
ZJ with np249 T-L ZJ Grand Cherokee Forum 2 10-05-2008 06:17 PM
Replacing NP249 seal ZJ Limited ZJ Grand Cherokee Forum 7 09-16-2008 10:19 AM
Np 249 to Np249 lol 98ZJlimited ZJ Grand Cherokee Forum 3 09-20-2007 09:06 AM
