np249 to np242 swap no part time light - JeepForum.com
post #1 of 7 Old 02-06-2013, 04:47 PM Thread Starter
pinky38
I swapped out my np249 for a np242. It was a direct swap no ds changes. Bolted right up. My problem now is the part time light doesn't
light. Instead lo lights up. All other lights are correct.
pinky38 is offline
post #2 of 7 Old 02-06-2013, 04:50 PM
lil_joe
What year ZJ do you have, and what was the build date on your 242?
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #3 of 7 Old 02-06-2013, 04:55 PM Thread Starter
pinky38
I have a 98 5.2 242 came from a 96
pinky38 is offline
post #4 of 7 Old 02-06-2013, 05:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did you need to plug in any electrical connections so the VIC would work correctly?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 7 Old 02-06-2013, 05:19 PM
dnuccio
Hunter
when you swap, for the VIC lights to work correctly, you need to go behind the VIC, and find the 2 red connectors and the 2 black connectors. the red ones should be plugged together. unplug them, and plug the black ones together. should work right now, unless your 242 did not come out of a ZJ.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 7 Old 02-06-2013, 07:35 PM Thread Starter
pinky38
thanks for the help. That fixed the problem!
pinky38 is offline
post #7 of 7 Old 02-06-2013, 07:46 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
thanks.
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
