NP249--Np242 swap - JeepForum.com
post #1 of 4 Old 05-21-2008, 09:13 PM Thread Starter
capone518
NP249--Np242 swap
I installed a NP242 in my 94 Jeep Grand Cherokee V8 , everything was cool until it started leaking fluid betweeen the trans and t-case. Upon further inpection the input shaft on the 242 is shorter than the 249. I tore down the 249 and took the input shaft out of it to replace that of the 242. All seems good there until the snap ring that goes on the end of the input shaft wouldnt go on. The input shaft of the 249 uses a narrower bearing. I think i just need to pop the bearing out of my 249 and install it in the 242 case, either that or use the whole front case of my 249 on the rear of the 242 case. My planetary gears on the 249 were shot, but the input (annulus is in good shape, which I need for an input gear. The input gear of the 249 fits in the 242 planetary and feels good, however the input gear from the 242 does not fit in the 249 planetary. Dont want any problems, anyone else seen this. Would I be better off buying a planetary set for a 249 and using my whole front case.
capone518 is offline
post #2 of 4 Old 05-21-2008, 09:18 PM
jeepheller98
im pretty sure you need to use the whole front off the 249, http://jeephorizons.com/tech/tcase.html
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #3 of 4 Old 05-21-2008, 09:30 PM Thread Starter
capone518
so I will have to buy a new planetary gearset for my 249 front half or will the planetary from the 242 work. Im worried that the sun gear will wear funny on the 242 s planetary
post #4 of 4 Old 05-21-2008, 10:13 PM
Virmagicus
Virmagicus's Avatar
What year is the 242 TC ? When the cone is upright you have to pull up on the shaft in order for the snap ring to fit. Make sure the input shaft is fully seated and the TC is in 4 low.
Jeff
Virmagicus is offline
Transfer Case Swap Info NP249->NP231 & NP242 JrMechanic ZJ Grand Cherokee Forum 3344 03-21-2017 10:05 AM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
How do I swap a NP249 for a NP242? FoxriderUTI ZJ Grand Cherokee Forum 1 10-01-2009 06:45 PM
to do np249 to np242 swap or not and wondering about some minor things 2tone93zj ZJ Grand Cherokee Forum 12 12-03-2008 05:39 PM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
