NP249 to NP242 SWAP - JeepForum.com
post #1 of 3 Old 11-29-2004, 06:22 PM Thread Starter
tb007
NP249 to NP242 SWAP
i have a 94 grand cherokee with a 4.0 limited, and a quadra trac transfer case that has a bad VC, i have the opprtunity to get a NP242, from a 90 cherokee limited, what i need to know, was the possible compatibility issues, the only bad possibility is that the splines would be the wrong splines? right?
Thanks,
Tom
eddited for new information
tb007 is offline
post #2 of 3 Old 11-30-2004, 12:12 AM
zjjeeper
There are 3 different compatibility issues to check, but all are easily overcome.
If the 242 is from an Auto Cherokee then it will probably bolt right up..
and if it from a 6 cyl cherokee you are probably o.k.
here is what to look for
23 spline input.... (that is what your 249 is)
There are 2 different input cup lengths, depending on the vehicle, some where long, and some were short, the only way to know is to pull your 249 and measure, the measure the 242.
The good news is:
Same Linkages (just need to change the bezel in the ZJ), Same driveshaft lengths (you dont need to change your driveshafts, because 242 and 249 share the same outer case dimensions)
Overall you have a pretty good chance that it will bolt right in.
If it is a 21 spline unit you can swap your input cup from your 249 into the 242 after a little minor surgery of the cases
1997 ZJ, knobby tires and stuff..
zjjeeper is offline
post #3 of 3 Old 11-30-2004, 11:50 AM Thread Starter
tb007
on closer inspection of the case...
today i went to look at the case, and it's still in a running 90 cherokee, ( it is an auto, and a 4.0) the only problem with it is that it wouldnt go into 4 LOW... now, this jeep has been pretty beat up off road, is it realistic that it's just the linkage thats bent?.. and if not, why wont it go into 4 low, and is this a hard fix? (everything else works just fine, inclusind 4 full and part)
Thanks again
Tom Bell
tb007 is offline
Transfer Case Swap Info NP249->NP231 & NP242 JrMechanic ZJ Grand Cherokee Forum 3429 07-18-2017 07:20 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
How do I swap a NP249 for a NP242? FoxriderUTI ZJ Grand Cherokee Forum 1 10-01-2009 06:45 PM
to do np249 to np242 swap or not and wondering about some minor things 2tone93zj ZJ Grand Cherokee Forum 12 12-03-2008 05:39 PM
NP249--Np242 swap capone518 ZJ Grand Cherokee Forum 3 05-21-2008 10:13 PM
