NP249 Input shaft Compatible with AX15/NP231 Combo? - Page 2 - JeepForum.com
post #16 of 20 Old 05-26-2011, 01:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
correct. 1.550" input on the 46rh, the 545rfe also uses a 1.550" input with 23spl.
fun fact, any trans that will bolt to a magnum motor will bolt to a 4.7l powertech motor.
ratmonkey is offline
post #17 of 20 Old 05-26-2011, 02:15 PM
speedbucket
wait a second? does than mean a WJ 4.7 with the545rfe and a 242 would give me a direct swap for my 249?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #18 of 20 Old 05-26-2011, 03:27 PM Thread Starter
Rynfw100
line up inputs side by side.
i think the ax-15 takes a .840 exposed input shaft. check the tj forum, they'd know better than here. the only auto grands that DIDN'T have that length exposed shaft were the early v8's.
You mean the AX-15 uses the .840 exposed input shaft out of the 231, the 249, or both? (Let's assume that the .840 is correct.) I guess what I'm asking is will the exposed shaft's length be reduced between Transfer Cases?
Rynfw100 is offline
post #19 of 20 Old 05-26-2011, 04:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
No vss on the wj cases. Otherwise it swaps.
Exposed input lengths are universal in the nv/np transfer cases.
post #20 of 20 Old 05-26-2011, 05:17 PM
speedbucket
who needs a speedo anyways, im just slightly intimidated by swapping inputs
although i did have a buddy that could consistently guess within 5 mph of his speed by the pitch of TSLs. it was impressive to watch
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
Retaining/Snap Ring on np231 input shaft NickkciN ZJ Grand Cherokee Forum 3 07-10-2010 12:14 AM
ZJ NP249 to NP231 swap question veedubshafer ZJ Grand Cherokee Forum 21 05-03-2009 05:54 AM
ZJ with a factory NP231. 23 or 21 Spline input shaft?? 90SaharaJeep ZJ Grand Cherokee Forum 2 02-23-2009 04:02 PM
NP249 Vs. NP231.. Reloader77724 ZJ Grand Cherokee Forum 14 08-17-2006 01:40 AM
