NP249 Input shaft Compatible with AX15/NP231 Combo? - JeepForum.com
post #1 of 20 Old 05-25-2011, 01:24 AM Thread Starter
Rynfw100
Ok here's the deal, I bought a Transfer Case thinking it was a NP231 out of a 1994 YJ, however after looking at the case, identifying the rear case part number to the transfer case (it doesn't have the identifying tag on the rear), and basically taking all the pictures I found and matching it to the transfer case, It seems to be a NP249. These were in ZJs as you all may know, and you guys switch the input shafts to make them work with 242s and 231s.
My question is this, will an input shaft out of the NP249 go into a NP231 (I know there was a change in the shafts from 1994-1995) and then the input shaft link up to an 1997 TJ AX-15 since the output shaft of the transmission is 23 spline, just like the input shaft to the NP249?
I'm just trying to justify, instead of trying to recoup my losses, seeing if the input shaft will work. Max already got the idea in my head Any help would be awesome. Thanks!
Rynfw100 is offline
post #2 of 20 Old 05-25-2011, 03:18 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Casting numbers don't mean much when identifying cases.
Verify the number of modes the selector lever catches in. 3=249, 4=231, 5=242
ratmonkey is offline
post #3 of 20 Old 05-25-2011, 08:38 AM Thread Starter
Rynfw100
That's not what I asked... but ok. I forgot to mention in the first post that it has 3...
Rynfw100 is offline
post #4 of 20 Old 05-25-2011, 08:56 AM
Obie95Sahara
Since you say it has 3, it would be a 249.. I'm not sure if the input shaft fits or not, I have no experience in that area..
Ratmonkey is pretty damn knowledgeable in transmissions & transfer cases.. He was just letting you know another way to identify which case you have... Someone on here may be able to help you out, but I can bet that with the way your response sounds it won't be Rat, lol. Maybe it's just me, but your reply didn't sound too polite..
Obie95Sahara is offline
post #5 of 20 Old 05-25-2011, 10:04 AM Thread Starter
Rynfw100
If it came off that way, I apologize. I'm only more or less wondering if the input shaft would be compatible with the AX-15, since I've already identified the case itself.
Rynfw100 is offline
post #6 of 20 Old 05-25-2011, 03:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
231, 242, and 249 all use the same input and planetary reduction sets, just with different exposed input shaft lengths that are dependent upon the TRANSMISSION they are attached to.
some cases behind 4cyl jeeps use 21 spl inputs. the reduction sets are the same so they work with 23 spline or 21 spline inputs.
post #7 of 20 Old 05-25-2011, 03:27 PM Thread Starter
Rynfw100
So Basically I have to determine if the input shaft will work with the transmission (AX-15) to use it in my case, but it should mate with the NP231?
Rynfw100 is offline
post #8 of 20 Old 05-25-2011, 04:35 PM
speedbucket
someon will correct me if im wrong
if your swapping inputs then the gear cut change in mid 94 doesn't matter
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #9 of 20 Old 05-25-2011, 11:28 PM Thread Starter
Rynfw100
Courtesy of Novak
Since the Gear cut is the one that moves on the innards of the Transfer Case, won't having the two different cuts eventually wear each other out... causing damage?
Rynfw100 is offline
post #10 of 20 Old 05-25-2011, 11:43 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
They're noisy in 2wd and hi, in low the case about locks up. Don't mix gear cuts
post #11 of 20 Old 05-25-2011, 11:58 PM Thread Starter
Rynfw100
Any way to determine what gear cut a shaft has? Early or Late?
Rynfw100 is offline
post #12 of 20 Old 05-26-2011, 05:57 AM
speedbucket
by the manufacturing date on the case tag, most people say the cutoff date for the early gear cut is 94.5
post #13 of 20 Old 05-26-2011, 09:33 AM Thread Starter
Rynfw100
No Tag on the case.
Rynfw100 is offline
post #14 of 20 Old 05-26-2011, 01:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
line up inputs side by side.
i think the ax-15 takes a .840 exposed input shaft. check the tj forum, they'd know better than here. the only auto grands that DIDN'T have that length exposed shaft were the early v8's.
post #15 of 20 Old 05-26-2011, 01:27 PM
speedbucket
, which is mine (93 v8) and its got 1.5" input for the 46RH correct?
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
Retaining/Snap Ring on np231 input shaft NickkciN ZJ Grand Cherokee Forum 3 07-10-2010 12:14 AM
ZJ NP249 to NP231 swap question veedubshafer ZJ Grand Cherokee Forum 21 05-03-2009 05:54 AM
ZJ with a factory NP231. 23 or 21 Spline input shaft?? 90SaharaJeep ZJ Grand Cherokee Forum 2 02-23-2009 04:02 PM
NP249 Vs. NP231.. Reloader77724 ZJ Grand Cherokee Forum 14 08-17-2006 01:40 AM
