-   -   NP242J no reverse in 4x4 low (http://www.jeepforum.com/forum/f13/np242j-no-reverse-4x4-low-1515419/)
saylor 04-27-2013 06:00 PM
Im not too familiar with the 242's. Im a 231 guy. For some reason, my 4Low only works in forward, but no such luck in reverse. I went under and adjusted my linkage, but still no luck. I went to put it in 4High Part time to try reverse but still no luck. I put it in 4High full time and got it to go in reverse. Ive read in forums theres something that has to do with a Center Diff. Im mechanically inclined, so if someone could enlighten me on how to diagnose/fix this issue, I'd certainly appriciate it!
Thanks,
Saylor
ratmonkey 04-28-2013 08:20 AM
The case is exactly the same as a 231 in high sand low range. Nothing about going backward is different than forward
Check your transmission mount, it may be bad pulling the linkage and case out of gear in reverse.
saylor 04-28-2013 03:00 PM
Everything looks good With the mounts. I noticed that while in 4H/L it kept popping in and out. id stop, put it in neutral or switch from 4H to 4L and it would do fine again. Linkage issue?
ratmonkey 04-29-2013 07:26 AM
Normally adjustment or transmission mount. Sounds like mount though.
The time now is 04:05 PM.
