Quantcast NP242 tutorial - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > NP242 tutorial
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 04-29-2009, 06:22 PM   #1
baxy
NP242 tutorial
should I post pics of a complete reseal I did today on an NP242?
I dont have premium membership so I cant post it in the technical area
baxy is offline   Reply With Quote
Old 04-29-2009, 06:28 PM   #2
-cAcHe-
pics pics pics..you can post you have over 50 posts.......upload them to photobucket and use [img] tags.
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline   Reply With Quote
Old 04-29-2009, 06:30 PM   #3
baxy
1998 JGC 4.0 typical NP242 tcase
Old 04-29-2009, 06:31 PM   #4
baxy
remove speed sensor and tin seal protector from output shaft
remove washer and first snap ring
Old 04-29-2009, 06:33 PM   #5
baxy
remove seal and second snap ring under seal
remove bolts holding rear extension housing on
Old 04-29-2009, 06:34 PM   #6
BLACKzj52
THOSE F-IN LOCKRINGS HAVE MADE MY LIFE HELL WITH THAT 242
/rant
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 04-29-2009, 06:49 PM   #7
baxy
remove extension houseing by tapping on raised pieces carefully it can be tight
remove bolts holding case halves together , tap apart look around the edges there are slots to wedge a screw driver into
Old 04-29-2009, 06:50 PM   #8
baxy
/rant
lots of time I find them upside down which makes them really hard to remove
Old 04-29-2009, 06:52 PM   #9
baxy
remove snap rings holding sprockets to shafts.... note the sprockets are different and only go up one way
chain and sprockets removed main shaft removed just pull straight up
ok pry indetween shift fork and rooster comb to get the first shift fork out sorry I didnt get a pic
it will take alot of pressure but it will come
I know the proper way is to remove the roll pin but I end up fiddling around forever and sometimes cant get it out
after you get the first one out you can just rotate the rooster comb up and wiggle out the inner shift fork
then remove the roll pin and we will assemble it according to the manual
Old 04-29-2009, 06:56 PM   #10
baxy
remove input seal retainer and inner snap ring on input shaft
Old 04-29-2009, 06:58 PM   #11
baxy
remove input shaft and tap out input bearing
Old 04-29-2009, 07:01 PM   #12
BLACKzj52
i can deal with that, but mine warped and got weak, so when they were in the little grooves they slip into, they spun around. this let my tailshaft move forward and backward and at highway speeds this blows ur seal.
believe me, iv been through 5 of those dam seals already. i got some new rings from the dealer tho so this friday im gonna tackle is and see if it holds.
if not im putting a hammer through the sob
My Build Thead
Facebook
RIP Troy Edwards
Old 04-29-2009, 07:02 PM   #13
baxy
remove the shifter detent and the range switch
wiggle out rooster comb it only will come out one way
save the oring and plastic ring that comes out the other side
Old 04-29-2009, 07:04 PM   #14
baxy
take your stock snap ring to a bearing supplier and match it up with the snap rings that have the two eyelets they are a far superior ring we change them up all the time it is actually the fix for the NP241 output shaft snap ring failure
Old 04-29-2009, 07:06 PM   #15
baxy
ok before we start re assembly lets change the trans output seal
remove the seal
Glock Forum
